Good point, I was referring to the one I linked too, which of course you are correct in saying it may not be wired up the same. I'll rephrase it, the connector is good to fit a PC Engine / Turbo Duo.It definitely works on a Core Grafx 2 as i've used one on mine. I'm sure i've used the same cable on my Turbo Duo as well.its better not plug this into anything before checking the wiring though.
sorry,i dont understand.
bambero has the cable in question,alot of cables look the same,going by those two variables alone how do you think it will work with a certain system without checking the wiring?
