@Thread
In regards to the SCART purple output hue, there is a problem with the Green Signal - this may be a Video output or Cable fault.
I do so appreciate good comparisons and this thread has started well, but I will state that the effort with the GBS comes across as an afterthought.
@AmmoJamo
You should inform the user the version of GBS you are using as well as the input method - for the Amiga there are 4 possible input methods which includes
RGB-S / RGB-HV / Composite and Component Y - Cb Cr
Each of these variables will have an effect for the de-interlacing and picture re-integration process. I would also state that it is widely know that the GBS under performs on LCD / OLED technology that forces 60Hz - This is mainly because its it designed for the Arcade Market that uses CRT technology - IMHO if one is to show the GBS under LCD / OLED then they should show this under a CRT solution for comparison.
Sadly when it comes to Video there is very simple way to look at it, and thats compression -
RF - Two wires contain the RGB, SYNC video components as well as Sound
Composite - Two wires contain the RGB and SYNC components
SVideo Y/C - Three wires containing the RGB and SYNC (as Choma, Luma, ground)
SCART RGBs - Five wires contain the RGB and composite SYNC information
SCART RGBhv - Six Wires Contain the RGB and separate SYNC Information
YUV is a different colour space, but is essentially a non compressed component signal
You have made a great start on the thread - keep up the good work.
