2025-09-09 : Bumped and updated stock numbers.
These items have been built by myself and are fully tested before shipping.
Ripple IDE controller for A2000 / A3000 / A4000 by LIV2 - Gold plated edge connector - €56 / $59 ( 2pcs available )
OpenPSX2AMIGA - Use PS1 or PS2 controllers on your amiga or c64 - €30 / $32 ( 3pcs available )
RGB2VGA Ultimate with real DB23 - Convert the RGB signal to VGA with selectable filters to avoid jailbars - €29 / $30 ( 3pcs available )
A500 PS/2 Keyboard adapter - works on both TYPE A and TYPE B variants - €14 / $15 ( 3pcs Available )
WaveTablePI - Including PI Zero2 and SD card - €49 / $52 (1pcs available )
WaveTablePI - Without PI Zero2 - €29 / $32 ( 2pcs available )
Gameport to USB adapter USB-C - Use classic gameport joysticks and gamepads on modern computers - €32 / $35 ( 4 Pieces available )
2mb GEORAM for c64 - GW4301 - Gold plated edge connector - €33 / $35 ( 1pcs Available )
For pictures of individual items contact me
Payment by IBAN or Paypal as "Friends & Family"
Tracked shipping inside EU should be about €15
Tracked shipping outside EU should be about $11
These are all Open Source projects that you can also find and build yourself, all the info is at these links :
github.com
github.com
github.com
github.com
github.com
github.com
Edit:
GitHub - LIV2/RIPPLE-IDE
Contribute to LIV2/RIPPLE-IDE development by creating an account on GitHub.
GitHub - SukkoPera/OpenPSX2AmigaPadAdapter: Playstation to Commodore Amiga/CD32 Controller Adapter
Playstation to Commodore Amiga/CD32 Controller Adapter - SukkoPera/OpenPSX2AmigaPadAdapter
GitHub - EmberHeavyIndustries/AMI-RGB2VGAULTIMATE: The Ultimate Amiga RGB to VGA filtered buffered let-those.ugly-barrels-away adapter
The Ultimate Amiga RGB to VGA filtered buffered let-those.ugly-barrels-away adapter - EmberHeavyIndustries/AMI-RGB2VGAULTIMATE
AMIGA 500 PS/2 KEYBOARD ADAPTER - Share Project - PCBWay
AMIGA 500 PS/2 KEYBOARD ADAPTERThis is a tested and working circuit.Do not be sad if your Amiga 500 keyboard is not working. AMIGA 500 PS/2 KEYBOARD ADAPTER will help you to use your Amiga 500 with yo...
www.pcbway.com
GitHub - scrapcomputing/WavetablePi: A wavetable module powered by a Raspberry Pi Zero 2W and mt32-pi
A wavetable module powered by a Raspberry Pi Zero 2W and mt32-pi - scrapcomputing/WavetablePi
GitHub - necroware/gameport-adapter: GamePort adapter to connect old DB15 joysticks to USB port
GamePort adapter to connect old DB15 joysticks to USB port - necroware/gameport-adapter
GitHub - garrettsworkshop/GW4301: geoRAM-compatible RAM cartridge for Commodore 64
geoRAM-compatible RAM cartridge for Commodore 64. Contribute to garrettsworkshop/GW4301 development by creating an account on GitHub.
Edit:
OK I won't make you wait any longer, I will make the refund for you as soon as possible.@RetroFletch Another week without any communication or solution, again I'm requesting a refund. After two months of nothing, I don't think this is an unjustified request, can you please make this happen?
