Hi folks, here's something i've been tinkering with the last few months of spare hack time
I got an old DVB-T Receiver for free and was nearly going to throw it away after numerous attempts to give it to someone who might get some use out of it, then it struck me that the casing made an ideal shape to house my GBS 8220, SLG3000 and Sync Strike!
So here's what I did: -
This is the box. Quite a standard looking Phillips thing: -
Original gubbins comes out: -
This is what I want to put in: -
But they need a bit of hackery to fit!
Took the switch off the sync strike and hard set to power from PSU with a wire jumper
Wired in the RGBS cable to the sync strike. And took off the VGA connector.
And it plugs into the GBS. I've also taken off various connectors that wont be used on the GBS too -
Wired up a jump power lead from the GBS to the SS: -
Put a faceplate on the SLG: -
Took off the VGA connectors. I'll wire these to ports together.
All wired up pin to pin and showing a rough place the SLG will sit.
Here i've wired in the Audio ports to the SS, and took some power wires from the GBS ready to switch up.
A rough idea were i'm at now.
I want the 4 buttons to be discreet. I had the idea to have them poke out of the original grill holes. I had to enlarge them a little though.
here are the wires for the buttons
and the buttons
I also need an LED
Wired to the original SMD LED space (I took the original off)
Here is the power connector and switch (with unit on showing LED lit)
I painted the case Satin Black
And then went mental with a glue gun!
Some rubber feet underneath: -
The back now looks like this: -
The buttons to access menus
finished unit from the front (I want a sticker for it, but not sure what to put on it yet)
And running with my RGB modded CD32
( https://www.amibay.com/showthread.php?p=268275#post268275 )
Thanks for looking!
and the buttons
I also need an LED
Thanks for looking!
