SD card bracket for an SD card extension cable
  • Thread starter Thread starter protek
  • Replies Replies 3
  • Views Views 996
protek
Finland
Oulu, Pohjois-Pohjanmaa
I have an SD Disk ][ emulator for my Apple IIGS, which is also able to emulate hard disks, although not very fast. The emulator firmware is constantly updated which causes me to open up the IIGS every time I want to upgrade it. I wanted to spare the latches of the IIGS case top so I thought I'd get an extension cable for the SD card. The extension came in its own casing but I really didn't want it just hanging outside of the computer case so I thought to I'd make a bracket for it.
I designed the bracket in AutoDesk 123D Design. I wanted to be able to utilize the the port openings in the back of the IIGS, so I used the dimensions of the parallel port.
I had the bracket 3D printed by a friend of mine and I think it came out pretty nicely. Had to do a bit of manual modification to make it fit better though. I've since updated the 3D model accordingly.
The other end of the cable goes to the SD card reader of the SD Disk ][ and the bracket is installed on one of the port openings.
Edited_ImageEasyImageEditor_20150219_110.jpg Edited_ImageEasyImageEditor_20150219_111.jpg
There is one issue though. The SD Disk ][ will not read the SD card if it's in the extension. Is the cable too long or is it getting too much interference? Can this type of flat cable be shortened or should I just use regular flat cable instead?
Wow! That turned out quite nice. I hope you get the extension working soon. :)
Heather
That's a cool SD extension. Where did you buy it? It's probably too long though. Do they come in shorter lengths?
Bryce.
Thanks! I bought the extension from AliExpress, if I remember correctly. It pretty much same as this on WoldemortBay.
I definitely wouldn't need one this long. I think a 10-15 cm cable would be enough for my needs but not sure if this type of cable can be shortened.
