For Sale Sega Mega Drive / Genesis Pad to Amiga adapter
  • Thread starter Thread starter mwarr81
  • Replies Replies 41
  • Views Views 2410
Received thanks!
Can you please tell me where I can get the .stl file for the case enclosure so I can print it myself?
Edit: Apologies, I see now that the case is for sale separately. I understand if you don't want to share the file, just checking in case it happens to be publicly available. Thank you!
Received thanks!
Hi, it is publicly available and happy to share link. I'll message you with it
Hello,
With this adapter and my SG PROPad, I could play Turrican with :
B : Fire1 (with Auto Fire)
C : Jump
Right Trigger : Fire1 (for lazer)
Anyway ... if I use Jump for C, I lost second button, so my question, is it possible to add/modify the adapter for : When we push the A button, to send Fire2 in amiga ?
Thank you
This wiil give me as 4 buttons (Fire + Jump + Fire Auto + Fire2 with A button :) )
Do they support 7-button CD32 mode? Ah I see they are completely passive with no logical element. Nevermind.
Hello,
C : Jump
Thank you
Hi. you can not have fire2 and an up button on B or C at the same time with this adapter, so for Turican you either need to press the space key for fire 2, or use the 'up' on the d-pad.
However I have been considering re-wireing some gamepads that will provide this functionality for the future, and to sell them here but currently not available, and I was not sure if this was something that people would like either so I was still deciding if I should offer this or not.
Too bad, but i understand.
I'm sure this could be interesting for lot of people
(Marked as sold/completed by mwarr81)
So does that mean, no it doesn't support all CD32 buttons?
These adapters just work as a 2 buttons joystick. I will eventually do a Mega Drive adapter that does support CD32 buttons.
I am also working on a firmware update for my SNES to Amiga adapter which is in testing phase and that will support all the CD32 buttons. It's almost done im just working on fixing a small bug. Probably after Christmas now.
Would this work with the Master system pad, or is it the wrong 2 buttons on that controller?
You don't need anything, the Master System Pad can be connected straight to the Amiga or C64.
So can Mega Drive, it is the remaping funktion i am after. I just dont like the form of the Mega Drive, prefere Master System.
The Mega Drive cannot be connected directly to the Amiga. It looks like it's working but there is a small electrical problem. On the C64 it's even worse. That's the main purpose of this adapter, the remapping feature is a bonus.
It should work, you can have an up button but you will loose fire 2, or you can keep fire 2 and loose the up button. I've used other pads this way but I don't have a master system pad to test but it must work.
  1. matt020
  2. hyperfan
  3. ClassicA
  4. amigean
  5. patters
  6. Tedzogh
