Sold Single Board Computer Socket7 - suitable for installation inside the Amiga
AlessandroBilbao
Rating - 98.3%
59   1   0
Italia
Imperia
Single Board Computer for Socket7 CPU
I had this single board computer along with other boards, it was tested with all Phil's Computer Lab DOS Benchmark Packs, memtest86 + and it passed all the tests.
Superb Socket 7 card all in one, directly installable in an Amiga 2000 or in a 3000/4000 modifying the daughterboard (I tested it on my A4000).
In short:
Accepts Pentium, PentiumMMX, Cyrix, IBM, SGS, AMD K5, K6 CPUs. Vcore ranging from 2.0v to 3.4v. Bus ranging from 50, 60,66,75,83 mhz, multiplier from 1,5x to 5,5x. Have integrated in the rear panel all necessary: PS/2 for Keyboard and Mouse, serial and vga connector. Internally have Parallel, other serial, USB, and more... HAVE 44 PIN IDE CONNECTOR means that you can directly connect a hard disk 2.5" or a Compact Flash without the need for additional power and additional wires, very useful inside the amiga case. CAN CACHE UP TO 128MB! Intel TX only 64Mb.
It is a very nice SBC for having one complete PC inside your Amiga. I don't supply the CPU or even the memory but I imagine each of you has a lot of them. If you need them instead ask me in private.
Request € 70 + ppfee + shipping. (was 75€)
https://drive.google.com/drive/folders/1-r3lQTtBT21MV8JPqV8bkulzff8iCrBq?usp=sharing
OK, what's this? You can put into a Z3 slot, and you have a separate P1 computer in your Amiga's house?
Thanks,
Sax
Thanks,
Sax
You can use this in the ISA slots on your big box Amiga and then it uses the ISA Bus and therefore you have a PC inside your Amiga, I currently have one in my A2000 using its ISA Bus with a ISA Sound Blaster, has with this one VGA is usually built in
