Closed SIO2SD Pcb
  • Thread starter Thread starter piemmeweb
  • Replies Replies 41
  • Views Views 13676
My package has arrived already just 2 days from Italy to the UK, now that is FAST :thumbsup:
I had better order some parts now :lol::lol::lol: feedback on its way :)
My fingers aren't working too good today and my typing is dodgy so it would be nice if someone could verify what is written below and amend it if I have missed anything out :thumbsup:
1 - ATMEGA3216PU 40 pin plus the socket for it to sit in (IC1) DO NOT GET THE ATMEGA32A VERSION AS ITS THE WRONG ONE
1 - 74HC245N 20 pin plus the socket to sit in (IC4)
1 - 3.3V REGULATOR FOR SD CARD(1C2)
1 - XTAL 14.31818MHZ
2 - 22P CAPS FOR XTAL C1 AND C2)
5 - 22N CAPS (C5, C6, C7, C8 AND C9)
4 - 100N CAPS (C3, C10, C11 AND C12)
1 - TANTALUM CAPACITOR (10UF 10 - 35V) THIS ONE IS POLARISED (C4)
1 - 27 OHM RESISTOR (R 10)
3 - 220 OHM RESISTORS (R11, R12 AND R13) FOR LED'S
2 - 10K RESISTORS (R3 AND R1)
1 - 1N4148 DIODE (D1)
5 - PUSH TO MAKE SWITCHES (S1 TO 5)
2 - 6 PIN HEADERS DUAL INLINE ::: (JP2 AND JP3)
1 - 7 PIN STRAIGHT HEADER AND SOCKET FOR THE CABLE (JP1)
1 - 16 PIN STRAIGHT HEADER AND SOCKET FOR THE DISPLAY (JP4)
1 - LCD DISPLAY. I ORDERED THIS BUT CAN'T GUARANTEE ITS THE RIGHT ONE TILL IT GETS HERE.
http://www.ebay.co.uk/itm/221865370335 ITS A BUY IT NOW SALE
3 - LED'S OF YOUR CHOICE LED (1, 2 AND 3)
1 - POTENTIOMETER 2.2K (R2)
1 - SD SLOT [I HAVEN'T LOOKED INTO THAT YET OR THE SWITCHES]
TAKE A LOOK AT https://www.retrohax.net/sio2sd-for-atari/
AND http://sio2sd.gucio.pl/wiki/English
I hope it helps a little :)
Just in case anyone else also needs these parts, here is the ones I have bought (still some to arrive).
All of them are BUY IT NOW sales, the SIO connector is one of the things that I haven't really looked at yet but here is one option
http://www.lotharek.pl/product.php?pid=85
ATMEGA32-16PU
http://www.ebay.co.uk/itm/401092301657?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
L78L33 78L33 3.3V 100mA low drop out Voltage regulator (seems to be virtually the same as the one on one of the links I read)
http://www.ebay.co.uk/itm/111856486065?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
SD Card slot
http://www.ebay.co.uk/itm/331621398893?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
14.31818MHZ/14.31818 MHz Quartz Crystal THESE ARE NOW GONE!
http://www.ebay.co.uk/itm/400951387314?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3A
Switches
http://www.ebay.co.uk/itm/100PCS-SP...hash=item2cb83e061e:m:m94bxB0jwyHfU6B3Db-UAbw
Programmer for use AVRDUDE and AVR Burn-O-Mat GUI which supports fuse setting plus the USBasp driver and .BIN or HEX files.
I haven't programmed mine yet as I am waiting for the other bits to arrive so I can see if it works as it should as information is fairly scarce on settings etc.
"http://avr8-burn-o-mat.aaabbb.de/avr8_burn_o_mat_avrdude_gui_en.php"
http://www.ebay.co.uk/itm/251774774394
Same seller and item minus the 10 to 6 pin adaptor but with the windows driver link in the listing
http://www.ebay.co.uk/itm/USBasp-Pr...067c0f4&pid=100005&rk=2&rkt=4&sd=251774774394
Or if you are going to build a programmer cable for programming the ATMEGA32-16PU
http://www.ebay.co.uk/itm/New-10PCS...254914?hash=item43ffd98782:g:rOkAAOSw2gxYx5GJ
It would be great if some others share their finds and also how they programmed the flash external or internal xtal and fuses in the Atmel32, I'm stuck till the other parts come along. I am assuming the external xtal is added to the oscillator/clock option in AVR8 Burn-O-Mat under fuses menu i.e. 8.0MHz - 16.0MHz.
Any help/information would be appreciated :thumbsup:
