1. Will sata hard drives work in Amiga's using a sata to pata adapter such as this one?
http://www.ebay.co.uk/itm/PATA-IDE-...829?pt=LH_DefaultDomain_0&hash=item27bf36f285
2. When using CF adapters, how can I tell what cards will work in them? I have some adapters I bought from China ( http://www.ebay.co.uk/itm/320565083709?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 ) and the card I'm trying to use ( http://www.i4home.co.uk/20111006/1001.JPG ).
It's in a tower so the cables and power it requires is no prob. I tried to sort out the card in WinUAE disabling the harddrivecheck. It partitioned, formatted and installed WB fine in there and windows no longer sees it as a formatted disk. But when I put it into my A1200 on the 4 way i/f it either doesn't see it, stops anything else being seen on the ide chain, or occasionally i can get it to show up as 2 disks (I did partition them into 2x4gb) on the WB but no program knows what to do with them.
They show up with the wrong device names/numbers, hdtoolbox sees something but cannot recognise what it is. When I formatted it in WinAUE etc i installed SFS, I just cannot see what I am doing wrong. Any ideas anyone?
3. Recently I've been trying to play The Settlers, it used to work fine when I had an 030, but these days I have an Apollo 060 and it will not go past the copy protection screen. Is this a known problem?
Appreciate any insights.
