When I entered the '64 world I wasn't too happy with the price and/or availability of some accessories, so I just designed my own. Hopefully they will be useful to other people as well.
For each item you can either buy the PCB alone, or the PCB plus a kit with all the components you will need to build the accessory. Either way, you will have to DIY, I will not be selling pre-built devices (Temporary exception: I have a couple of built devices available, see below).
Note that some items require the soldering of some SMD components in the 0805 package. For those who are not comfortable with that, I am now offering to pre-solder them for free. If you require this service, please specify it in your order.
OpenC64Saver - SOLD OUT
OpenC64Saver is an implementation of the Computer Saver device developed by Ray Carlsen.
Note that these kits are not suitable for the faint-hearted, since they require soldering some surface-mount components (0805 package). You will also have to use a variable voltage source and a precise multimeter to set the cut-off point.
Kit contains:
Prices:
OpenC64Cart 8k - SOLD OUT
OpenC64Cart is an 8 KB Cartridge for the Commodore 64. It allows multicarts and comes with a reset button.
Kit contains:
Prices:
OpenC64Cart 16k - SOLD OUT
OpenC64Cart16K is the 16 KB counterpart to OpenC64Cart. It supports up to 4 images in a single cart.
Kit contains:
Prices:
Open2327RomAdapter - 11 KITS AVAILABLE
Open2327RomAdapter is an adapter that allows the use of a 27xxx EPROM in place of a 2364 PROM. This is mainly useful for replacing the KERNAL and other ROMs in Commodore 64 and VIC-20 home computers and 1541 drives.
This kit requires the soldering of three 0805 SMD resistors.
Kit contains:
Prices:
OpenC64MegaDrivePadAdapter - 1 PCBS + 1 KIT AVAILABLE
OpenC64MegaDrivePadAdapter is an adapter that allows the safe connection of a Sega Mega Drive/Genesis controller to a Commodore 64 computer. Also works with Amiga!
Kit contains:
Prices:
OpenC64TapePortBreakOut - 10+ PCBS AVAILABLE
OpenC64TapePortBreakOut is a PCB that breaks out all the pins on a Commodore 1530 Datassette Connector. It is mainly useful for building Tapuino devices.
NOTE: PCBs currently on sale have a BLUE solder mask.
Kit contains:
Prices:
Payment methods accepted: PayPal Family & Friends (or add commissions), Bank Transfer, Satispay (for Italian buyers)
Items will ship worldwide from Italy. All shipments will be trackable and at cost. As a rule of thumb, shipping for up to two-three kits (total weight up to 100 grams) should be 4,30€ to Europe, 5,20€ to the US and 7,10€ to Australia. Add 6€ for tracked & signed for. Ask for exact quote.
Items are also on sale elsewhere.
Please note that I designed all of these boards primarily for my own use. I am open to suggestions and (constructive) criticism. All of my projects are Open Hardware, feel free to check out the KiCad design files on GitHub.
There is more to come, but this is it for the moment. Feel free to ask any questions.
My Sales:
Kit contains:
- 2x100nF 0805 Capacitor
- 1xZener Diode 4.7V
- 1x1N4148 Diode
- 1x3-pin Header Strip
- 1x3-pin Screw Terminal
- 2x2N3904 Transistor
- 1x820 0805 Resistor
- 1x220k 0805 Resistor
- 1x2.2k 0805 Resistor
- 2x1k 0805 Resistor
- 1x5K Variable Resistor
- 1xSRD-05VDC-SL-C Relay
Prices:
- PCB: 3,00€
- Kit: +5,00€
- With bi-color led R/B 3mm: +0,50€ over standard kit
- With RGB led 5mm: +1,00€ over standard kit
- With 7-pin male + panel-mount female DIN connectors: +2,00€ over standard kit (These are useful if you want to make an external device putting the saver in its own box)
Kit contains:
- 1x100nF Capacitor
- 4x3-pin Header Strip
- 2x2-pin Header Strip
- 5xJumper Cap
- 1xPush Button
- 1x28-pin Socket
Prices:
- PCB: 3,00€
- Kit: +3,00€
- With Machined-Pin Socket: +1,00€ over standard kit
- WinBond W27C512 EEPROM: +4,00€
Kit contains:
- 1x100nF Capacitor
- 2x3-pin Header Strip
- 2xJumper Cap
- 2x1n4148 Diode
- 1x10k Resistor
- 1xPush Button
- 1x28-pin Socket
Prices:
- PCB: 3,00€
- Kit: +3,00€
Kit contains:
- 3x10K 0805 Resistor
- 2x12-pin Header Strip
- 1x28-pin Socket
Prices:
- PCB: 3.00€
- Kit: +2,00€
Kit contains:
- 1xDB9 Male Connector
- 1xDB9 Female Connector
- 5x1n4148 Diode
- 2x2.2k Resistor
- 1x100k Resistor
- 1xBC547 Transistor (Or equivalent)
- 5x3-pin Header Strip
- 1x2-pin Header Strip
- 4xJumper Cap
Prices:
- PCB: 3.00€
- Kit: +5,00€
Kit contains:
- 1x6-pin Header Strip
Prices:
- PCB: 3.00€
- Kit: +1,00€
My Sales:
- Amiga
- Other Commodore Computers
