Closed Sunrize Industries AD1012 Sound Sampler 7 - 82KHz
  • Thread starter Thread starter jima
  • Replies Replies 7
  • Views Views 345
jima
West Midlands
A working pull from my A3000 (so sold as seen) this is a 12 bit audio sampler card for Amiga's (Zorro II or greater so A2000, A3000, A4000). Believed working but sold as seen. Details, specs and drivers may be found on the usual Amiga sites (Aminet, BBOAH etc.)
Summary specs with thanks to Amiga Hardware Database:
  • Analog Devices 2105 DSP - 10 MIPS, 100 ns instruction execution time
  • 12 bit playback and direct to hard disk recording
  • up to four audio channels
    • 1 track at 44 kHz with 68000
    • 4 tracks at 44 kHz with 68030
  • full duplex
  • mono sampling rates 7 - 82 kHz
  • frequency response 20 Hz - 20 kHz (-3 dB)
  • typical S/N ratio 70 dB
  • two eight order anti-aliasing filters
  • stores samples in 16 bit format for compatibility with AD516
  • mono RCA jacks for unbalanced line level audio input and output
  • 100 input digital gain levels
  • LTC SMPTE time code reader (24, 25, 29.97, 30 fps, drop and non-drop)
  • SMPTE input (RCA)
  • 64 kB fast static RAM, expandable to 256 kB
  • 8 kB ROM
£55 including UK postage. Sorry, can't do international at this time.
@jima please correct the proof of ownership on this sale. Thanks. (y)
Edit. In the future this needs to be written, not a copy and paste.
OK, confused - already added the AmiBaY name. Still an issue?
Proof of onwership needs to be witten as follows.
Forum name "Amibay",
Your forum name "jima"
And the date of sale.
What you have done rather than rewrite the proof, is copy and past the Amibay forum logo, which is a no-no!
Your date is also incorrect, today is the 18th, not the 16th!
OK, so noted, then may I suggest you add that note about written proof and logo usage to the posting guide in the Amiga section? :)
I suggest you have another read of the rules.
They are not hard to read or follow. We will not be adding any info regarding the logo.
Copied from the rules.
Proof of ownership for items of a value of £50 ( Total sale value inc fees & Postage ) or more is required if you fail either of the following conditions.
Is your post count less than 50?
You must provide proof of ownership.
Have you received less than 10 positive feedback? You must provide proof of ownership.
This is to be in the form of a photo of the item with a piece of paper showing the 1:- forum name, 2:- your forum name and 3:- the date the item is listed For Sale.
Interested. In the UK.
Note. Your declaration will be invalid until @jima adds valid proof of ownership.
Thread locked until proof has been corrected - contact a member of staff when you have the correct proof.
