Sold TF1230, prebuilt 68030 accelerators for the A1200
  • Thread starter Thread starter alenppc
  • Replies Replies 50
  • Views Views 5870
alenppc
Rating - 99.6%
262   1   0
Canada
ON/QC
These are no longer for sale, as they have been replaced by the TF1232.
The TF1230 is the latest edition to the line of TF accelerators for the Amiga. It features a 68030 running at 50 MHz, 64 MB ram and a secondary IDE connector (non bootable until the driver is loaded).
It requires Kickstart 3.1 or later to automatically add the Fast RAM. Your A1200 should also have the timing fixes done (E123C and E125C need to be removed, if present on your board).
While I will ship anywhere, you should keep in mind that EU countries are now charging VAT on any imports, and the minimum amount that is allowed to be declared is 150 euros regardless of the actual merchandise value.
The price for a populated board with a gold cpu is 160 USD. Payment via PayPal Friends&Family option.
The CPUs are socketed.
Shipping to most of Western Europe+UK is $22. (Extra $8 for 2 sets)
Shipping to most of Eastern Europe (e.g. Poland, Czech Rep.) is $32 (DHL only)
Shipping to the USA is $10
Shipping to Australia is $27
Shipping to Canada is based on your location, please PM me for a quote.
Also listed for sale elsewhere.
Make sure to check my other boards for sale:
TF330
TF536
TF1260
TF360
Does the TF-1230 require minimum Kick 3.1 or will it also work with 3.0?
It will work with 3.0, but you need to use the Addmem command to add the fast memory manually. You can also make a script that uses Skick to load kickstart 3.1 in RAM if you wish.
Thanks...
I have asked on exxoss as well about this. I just dont want to ask about the specific item here, because you can not do any more than you did.
I will try it. And thanks for the tip. ? I just wanted to know the minimum requirements, because you know these cards so well and I can not find any info anywere regarding kickstart requirement.
I don't want to edit the first post for fear that the forum will automatically "unapprove" it again, so I will just post here: I have updated the support page with info and instructions on how to run the board under 3.0.
Received and all looks great. I THINK the feedback system is no more?--correct me if I am wrong. So for now... this my POSITIVE FEEDBACK ? :-)
feedback system is down since the update, but hopefully will return in the update some time in the New Year.
This is good enough feed back for now
The accelerator arrived safely, thanks!
Crashing though - probably need timing fixes on my motherboard; I had removed E123C and E125C already, probably shouldn't have. I've ordered replacement 22pf caps and other parts to try to work through timing fixes. My board is a 1A revision.
Figured out the problem - boneheaded move on my part - I had an unattached IDE cable (that I sometimes connect to a CDROM) apparently causing IDE termination issues. Removed the cable, now everything is working perfectly!
Thanks a bunch!
BTW, don't know if the feedback system is back; if I find it I'll leave good feedback, otherwise please consider this POSITIVE FEEDBACK!
  1. scumm_boy
  2. amifan
  3. bdb
  4. DanBuchan
  5. cevoner
  6. bdb
  7. ghaleon
