As some of you may know , my brother has bought a farm and some machinery to go with it, one delightful purchase is a 1954 fordson major tractor.
now it does appear to of been dug out of a peat bog but thats just the result of 60 years outside in the rain.
However after buying the old girl and driving it ten miles down country lanes back to the farm it was clear that all is not well. The radiator leaked more water than the titanic and the brakes had almost seized on fully, the sight of the ford going at 10mph with gallons of water escaping from a corroded radiator and smoke bellowing from the brakes was indeed a joy on a summers eve.
Anyway , the old girl worked all summer , cutting , hay making and drilling post holes but it was pretty obvious that serious issues were waiting around the corner.
So i bought the tractor a new (recon) radiator and under full pressure we can see that the block / head was leaking and worse the water from the water jacket was being forced in to the oil.
So we stripped the engine and well... its dead jim
The block is cracked completely (early blocks are weak) and the crank is worn , one piston is picking up and the block is corroded so badly it is leaking water around the throttle shaft.
So what to do...
Fit a 6 litre, 6 cylinder low milage former boat engine ... obvious really.
more details and tractor diary on the way as the build continues
So what to do...
