Hi all
I am having a massive clear-out. All the following is free to whoever wants it all for the cost of the P&P (postage plus a small charge for the packaging time and materials).
A1500/2000/3000T/4000T keyboard - QWERTY layout, large 5-pin DIN plug (does not fit A4000D not sure about A3000D), all keys present, tested it and backspace/return keys are not functioning - given I have fixed a couple of these in the past, I suspect it needs a trace repairing which isn't too hard if you are handy - TAKEN BY RKAUER
Amiga A520 Modulators (2 of each with phono/coax lead) - not tested recently but were working previously - TAKEN BY ZETRO
A1200 PSU with 3 pin UK plug - working when last tested
A600 PSU with 3 pin UK plug - working when last tested
C= Tank style mouse (2 of) - both work as well as can be expected, need a clean though
C= newer style mouse - again working as well as can be expected - TAKEN BY SYKDIVINGIRL
Teac CD-224E slimline laptop CD ROM drive with black bezel - got this from someone on Amibay from Finland or Iceland (my memory is shocking so my sincere apologies) for building into my A1200 - this project won't go ahead so this is free to a good home - TAKEN BY MERLIN
A1200 Kickstart 3.1 ROMS - in full working order but have bent pins which need straightening - no big deal really - they were sent by a seller on Ebay and I complained when they arrived bent - he sent me a new set. - TAKEN BY MERLIN
A funny grey 23-pin floppy drive dongle...how about that for a description. It is grey, a pass thru dongle, with a disable? switch, opening it reveal a PCB with 2 toshiba chips with the code wiped off and a small sticker with what appears to read "EPS 3.93" or "EFS 3.93). God only knows....
9 pin serial port gender changers - female/female * 2
And now the memory....lots of loose ones, have tried to give the correct info for each:
Hyperram 4MB EDO Module - HYMIT05004 1Mx32 - 1 of
IBM 4MB EDO Module - 11D1320BA-70 1Mx32 - 1 of
JCI-S1S 72pin EDO Module (I am not sure of the size but no doubt someone will know) - 1 of
ACTM37A 64MB EDO Module ( I think - it has 4 * ACT 9642Y chips on one side which I think are 16MB each) - 2 of - TAKEN BY BINOX
Elpida 16MB EDO module (2M * 8) - 2 of
xMB EDO Module - 2 of (no idea of size, they have 16 chips on each module, numbered VT547404-6
16mb Parity SIMM module - 1 of - marked SGS with 8 * HY5117400B chips on and 1 * parity chips
Well thats it for now - all I have found to date...there will be more
Interested - PM me!
Andrew
Interested - PM me!
Andrew
