Hey all,
I have just got a viper 520 CD for my A 500+ and I was wondering if people could answer the following:-
(Please bear in mind that I have not fitted this yet as the CIA needs soldering by a wire and my soldering iron has died! Bad timing!
1. Does the ram auto configure? I am assuming this is the case as I cant find any software for it.
2. Is there an english manual anywhere as I can only find a german one? Google does a fairly good job at translating but still a little head scratching in places.
3. As this has kick 3.0 roms onboard could I use a rom switcher with it? If I remember there is a jumper onboard to dissable the the kick 3.0 rom but does this dissable the memory also?
4. I have read that you can change the kick rom to 3.1... Is this true? If so has anyone done this?
5. I will be using a ide to cf adapter on this but would also like to use an internal slimline cd/dvd as well... Would this be easy enough to do? I take it is just a matter of plugging it on one of the secondary ide ports and loading appropriate software?
Thanks in advance
Thanks in advance
