I was wondering, which A1200 motherboards don't need a timing fix to work correctly with ACA accelerators?
Thanks!![]()
Thanks!![]()
hi everyblue !! I had the same question,
then I tested this problem yourselfI bought 2x mobo rev 1D1 with original commodore timing fix and both mobo work very well witch ACA 1232 33
so I recommend for U 1D1 is the best revision for ACA
Just because you got lucky with some 1D1s that doesn't mean everybody else will. Some 1D1s will need the fixes.
For ACA's I've had the best success with 1D4 so as you can see it's pot luck!
has anyone tried 1.A and 1.B's
i havent had any problems with these.just for comparison's sake.
And don't assume just because it boots up and seems to work all is ok, you can get all sorts of funny issues, one 1D1 board I had here appeared to work flawlessly but if you attached a FastATA to it it would crash loading the FastATA driver if the ACA was installed!
I have ID 4 board with the newest ACA232 40 with MMU. Boots no problem but again some PCMCIA issues. Cannot load Compactdisk.device or freeze. I have a flash card with 1 GB in there. Also can't get online with a Oronco or 3com card. Card seems fine, no freeze just does not work. Subway works as usual in the clockport.
And it claims 100% PCMCIA compatible.
Have you tried the ACATune command -pcmciareset ?
Obviously I can't answer for him, but I haven't been able to make that function work at all in acatune. With my LAN adapter I can see on the LED when it gets reset and it doesn't happen with acatune -pcmciareset. If I use another tool for sending the PCMCIA reset signal, it is being reset as it should.
I use this one:
http://aminet.net/package/util/boot/CardReset
