WinUAE 2.8.0 (05.05.2014) Released Today
  • Thread starter Thread starter johnim
  • Replies Replies 4
  • Views Views 334
johnim
VIP
England
birmingham
http://www.winuae.net/
Standard A500 compatibility is now practically as good as it can get
without knowledge of blitter's undocumented internal logic design.
(Mainly problem with some demos that accidentally modify blitter
registers while blitter is already active)
New features:
- Full A4000T and A4091 NCR53C710 SCSI emulation.
- A590/A2091 and A4091 boot ROM GUI selection.
- Separate graphics filter settings for native and RTG modes.
- 256k ROM image inserted in floppy drive emulates A1000 KICK disk.
- Super Card Pro image file support (.scp).
- SLIRP network inbound port support (default: 21, 22, 23 and 80, others
can be added by editing configuration file)
- Input panel previously toggle-only events can be optionally set to on
and off state, audio/video recording input event added.
- Joystick/joypad can be used to control light pen cursor.
Updates:
- Remaining 68000 cycle-exact mode timing fixes.
- 68000 reading from write-only or non-existing custom register
compatibility improved.
- Big chipset edge case compatibility update, for example demos with
vertical "copper" bars work perfectly, real hardware glitches in
horizontal scaling are now accurately emulated and much more.
- 68040/68060 without emulating unimplemented FPU instructions is now
fully compatible with Motorola FPU emulation library, FSAVE special
FPU exception stack frames implemented.
- Programmed modes (Super72 etc) now automatically select best fit horizontal
resolution and is more compatible with different filter modes, also display
positioning is improved.
- Recently dumped Arcadia arcade system ROM images supported.
- Debugger full FPU and 68020+ bitfield, and other previously missing
68020+ only instructions supported in disassembler.
- Magic mouse + mousehack mode now always stops keyboard input when mouse
is outside of emulation window, even if window still has focus.
2.7.0 bug fixes:
- Unformatted partition hardfiles didn't mount and had incorrect geometry.
- Resolution autoswitch was not compatible with new interlace scanline modes.
- 68020 CE mode FPU exceptions fixed, broke for example KS 1.3 FPU detection.
- Sound glitches in games that use OCS compatible "fake 60Hz" screenmodes.
Bug fixes:
- Keyboard led indicator state syncronization problems fixed.
- Fixed very rare JIT FPU bug introduced in 1.2.
- Vertical centering works again, improved horizontal centering.
- Full tablet emulation boot guru fixed.
- Graphics glitches in some borderblank and border sprite modes.
- Master floppy write protection setting was not loaded from config file.
- Some narrow AGA modes clipped some pixels from right edge of display.
- A590/A2091 didn't work in all supported CPU modes.
- CPU polled disk reading was unreliable in some situations.
(05.05.2014)
New features:
Updates:
2.7.0 bug fixes:
Bug fixes:
Nice. I assume these changes'll filter out to the likes of FS-UAE soon enough. :thumbsup:
any help with run/playing napalm on this emu would really be nice :cool:
