Has anyone used one? And what success have you had?
The house we have just moved into is quite long and sprawling, with the main router being in the rear bedroom/office. The main BT Hub 4's wireless signal isn't the best and completely dies by the middle of the house where there is a chimney. So I've connected a Billion 7800N router to the network to act as just a wireless access point. This gives better coverage, but the front bedroom and front living room still only get a very faint 1 bar or less signal because of the chimney.
I need to get a signal into the front room for Sky On Demand, and for using laptop, tablet etc in there.
Powerline adapters are out of the question because of the strange way the mains electric is wired in this old (300 year+) cottage. The older part has a mains consumer trip switch unit, but this is then linked to another mains consumer trip switch unit in the newer extension. The router is in the newer extension and needs to get internet to the older part. Therefore I very much doubt a powerline adapter would work. Might be wrong but I doubt it.
Therefore I'm left with either running a long Ethernet cable through the house, but that isn't an easy option (already have one running the length upstairs the other way to get the broadband from the phoneline in the front bedroom to the router/wired network at the back), or a wireless repeater.
Doing lots of research into this the TP-Link TL-WA850RE seems highly recommended and not a bad price at around £30. I'm thinking I can plug it into the kitchen which is below the router and runs along the side of the house and bridges the back and front around the chimney, so hopefully this can get a signal through.
Will let you know how it goes. Going to buy one in the morning.
