X-BENCH
  • Thread starter Thread starter luy32
  • Replies Replies 45
  • Views Views 1172
Seems like X-bEnCh 0.90 Beta Released today :D
http://www.jimneray.com/xbench.html
X-bEnCh is an Amiga game launcher & More …
With 128 colors on screen (even on a simple A500), this Frontend can autoscan your hard-drive to find all your whdload games or your .exe and organize them in launching listings. X-bEnCh can also manage manuals listings and have an internal script system, the X-bEnCh Scripts (For non whdload games for exemple). It require very few ressouces and is compatible with all Amiga setups. X-bEnCh also have an integrated CLI fully compatible with the Workbench CLI features.
Actual features list:
- 128 colors on screen for all Amiga
- Autoscan and organize your whdload .slave and yours .exe from your HD
- Unlimited subdir level scan
- Internal script system
- Up to 6 launching lists in parallel
- Unlimited number of entry in each list
- Top15 listing
- Autoscan and use Whdload Tooltypes
- If no Tooltypes availables you can set up default Tooltypes.
- MegaRam mode to gain extra chipram without rebooting
- FastJump mode to jump where you want in a list with the keyboard
- Real time search engine
- Files/Dirs manager included (Xpl0rEr)
- Integrated cLi 100% Amiga cli compatible
- System friendly setup panel
- Dedicated installer for an easy installation
- Many more will come in the nexts releases.
and the changelog from recent versions:
:: X-bEnCh History :.
X-bEnCh 0.90Beta (05/08/13)
The history.txt is splited from the XB guide to light it a bit.(about20k)
A new icon is set for X-bEnCh.exe and X-bEnCh.guide.
The X-bEnCh.guide was updated but the setup part is still outdated.
Xinstaller0.6
-Fixed the textgadgets display bug.
-Internals fixs.
Xinit1.8
-Fixed an init bug if no Top15 was previously created.
-Internal fixs.
Xlaunch2.0
-Empty Top15 crash fixed.
-Top15 is no more displayed if it blank.
-If no Top15 file exist, autocreate one.
-Fixed the display lag in the checkerboard loader screen when
accessing datas. (checkerboard v0.4)
-Now the music'll not end before the display is closed in the
checkerboard loader screen. (checkerboard v0.4)
Xcli0.9
-Fixed the "topupdate" command if no Top15 exist.
Xplorer0.2
-Display refresh bug after deleting a file fixed.
X-bEnCh 0.90Alpha Fixed (16/06/13)
Xinstaller0.5
-Fixed a missed file in the install process. Should now work
even with a blank new install (Previously only work if you install
it on the top of a 0.8x release.)
X-bEnCh 0.90Alpha (06/06/13)
Xinit1.7
-Now update the Top15 list in the Init process.
-Now check if some args are sets with the setup for the loadwb cmd.
-Is now able to init to the Xplorer if set in the setup.
Xmenu1.6
-Bug with a mouse plugged in the joyport1 fixed.
-The menu is sorted with the Xplorer in 2nd position now.
-You can now use the "Enter" key to validate your choice.
Xlaunch1.9
-Top15 feature implemented.
-Multikeys Fastjump implemented.
-Added the display of the WhdL Requester if enabled in the setup.
-Bug with the Microsys joy/mouse adapter driver fixed.
-Fixed the repeat latency of the "Tab" key.
-You can now use the "Enter" Key to validate your choice.
Xcli0.8
-Added the "topupdate" cmd to manualy update the top15 list.
-Updated the "help" cmd.
Xplorer0.1
-Very first public version of the Xbench Files/Dirs manager.
Xsetup1.6
-Reactivity optimised.
-No you can use the setup (If you want) without mouse nor keyboard.
-Added a path requestor for the 6 launching lists.
-Renamed the "Boot From" to "Boot To" in the "Startup" tab.
-Added a LoadWB args textfield to the "Startup" tab.
-Added the Top15 On/Off switch to the launcher tab.
-Added the WhdLReq On/Off switch to the launcher tab.
-Look optimised.
-"Xplorer" option added to the "Boot To" switch in the startup tab.
Xexit0.6
-Better temp files cleaning before leaving.
Xinstaller0.4
-The ASL path requester is now disabled if you don't have rom 2.0+.
-Custom text font issue fixed.
-Bug when using a custom file system (SFS for example) is fixed.
-"D" (Directory) button is renamed to "P" for Path requester.
The awesome whdload/file managing tool got some updates!
X-bEnCh 0.91Beta (17/09/13)
Xinit2.0
-Init Crash (8000000B software failure) fixed.
-Unregistered wait timer reduced by 2.
-Minor bug fixs.
X-bEnCh 0.91Alpha (14/09/13)
Now with up to 272 colors with AGA (and always 128 for OCS/ECS)!
Big update of the X-bEnCh guide.
X-bEnCh is now donationware.
Xinstaller0.7
-Bad font display fixed.
Xinit1.9
-"CD Mode" update. No more try to write temp files on HD.
-The ugly colors of the Xbench logo on non AGA system is now fixed.
-New colorfull loading progress bar.
-Fixed the workbench bad palette bug on exit when a file is missing.
-Updated the datas files check'up.
Xmenu1.7
-Protracker replay routine fixed; now perfectly play .mod
Xlaunch2.1
-F1 to F6 shortcuts added to add a fast access to your listings.
-Now if a list is empty xlaunch just ignore it (As if it does't exist)
-Now if all list are empty Xlaunch exit to main menu.
-68060 Recognition fixed (In some case 68060 was recognised as a 68040)
-Internals fixs (Unneeded datas was previously loaded in memory)
Xpl0rer0.3
Xcli1.0
-Sysinfo command updated to 0.3 (68060 & ECS/OCS recognition enhanced)
Xsetup1.7
-Slow double redraw bug fixed.
-Updated the init text.
-Tabs reorganization.
-"MySystem" tab is now activated.
-Added the "CD Mode" option switch in the "MySystem" tab.
-Added the "SetClock" options to set date/time in the "MySystem" tab.
-Added the Whdload tab (Not yet available).
Xexit0.7
- Now correctly unmount all uneededs assigns on exit.
From this version it is donationware, still all features work but you get a startup delay without a key... quite frankly it well worths the donation to put it in the boot menu of CWB (or your setup) for a flashy drooling whdload menu :lol:
easily fixed ;)
I donated the first day this version was released.
An awesome frontend for our beloved WHDLoad game packs.
Jim is always implements extra stuff so I really wanted to support his effort.
/respect
Are you supposed to be showing that serial number to the public?
I don't think it's bad as the key is a file that needs to be placed to folder directory.
If you see the Serial is nothing more than the date plus the incremental registration number plus the version ID :P
Even if you have it, you can't do anything with it without the actual file :)
@-Acid-
yeah, why not? it's a whole keyfile that you get, the serial alone is nothing
btw kudos to mfilos for the shots, he made them as I am a bored old bugger LOL
edit: mfilos was faster :D
@keropi : Thanx for your advert ! :lol:
A new release will be available this weekend to fix some bugs :thumbsup:
From EAB :)
X-bEnCh 0.91 Beta2 is available !
As always you can download it on: www.jimneray.com
This release fix some bugs:
- "My System" tab in the setup no more crash your Amiga.
- Added a button to switch back to the old sound replay routine in the "My System" tab in the setup. Use it if you have some sound issue with the new one.
- Bad redraw of the workbench on exit is fixed.
- Fixed some temp files issue.
- Minors bugs fix.
See the complete History.txt in the archive for a complete info.
Lookin' forward to trying this out :thumbsup:
Thanks for the updates as always :cool:
New version seems to work just fine at last :)
Music using the old routine on My System fixed my issues.
Also I had issues with the command MinStack (in case anyone is using it).
I set it up for quite some time as:
C:MinStack 10000
Change it to C:MinStack 4096 or else X-Bench won't scan correctly your drawers on update and will Guru upon running the Launchers options.
Thanks for the updates Jim. Can't wait testing b3 :) (not to mention 1.0)
X-bEnCh 0.91 Beta3 is available : www.facebook.com/xbenchproject
-Bad scan of your hd by the setup fixed.
-Crash of the launcher after a scan fixed.
-Fixed bad display of the Whdload requester if this option is enabled in the setup/launcher.
-Minors fixs.
No need to change your stack all is fixed now. :thumbsup:
I know. I tested it and it rox now (at last) :)
Thanks for these updates man. Can't wait for next buffed version :D
X-bEnCh 0.91 Beta4 is available !
-Fixed a forgotten file check on startup.
-Fixed a forgotten temp file.
-New clean fadein/fadeout routine.
-Code optimisation.
-Fixed buggy & useless workbench redraw on exit.
-Minors fixs.
Mmmm their is still some weird bugs. Working on to, and update a release asap :)
X-bEnCh 0.91 Beta5 is available !
This release fix:
- The bad display of the longs names for registered users.
- The "CD Mode" crash when switching On/Off in the setup.
- The strange month/year bug with the Setclock in the setup
- The "Esc" key in the launcher in some cases.
This is the last beta of the 0.91. The next one (that'll be available soonly) will be a stable release. :cool:
