For Sale X-SID V2.0: SID replacement for 6581/8580 with Audio Boost
  • Thread starter Thread starter axel81
  • Replies Replies 83
  • Views Views 9648
axel81
Italia
Monza Brianza
X-SID V2.0 with AUDIO BOOST!
  • With the new version (AUDIO BOOST) we have improved the dynamics and the output level in order to obtain and get as close as possible to what is provided by the SID 6581/8580
  • Please remember that X-SID is not affected by standard and initial "BEEP" when it turns on!
  • Please remember that X-SID is not affected by typical distortion that you have on Swinsid version or other SID replacement
X-SID AUDIO BOOST - REVIEW from the WEB
Many passionate users in the music field (Commodore) have carried out comparison tests and were enthusiastic,check below if you want to listen
X-SID AUDIO BOOST (6581 emulation mode)
C64 - Music comparaison - Armsid vs X-SID on Wizball theme (6581 mode)
C64 - Game - Commando Arcade SE by Nostalgia (2015) With X-SID 6581
C64 - Graphics -Tribute to Bob Wakelin by Megastyle (2018) With X-SID 6581
X-SID AUDIO BOOST (8580 emulation mode)
C64 - Intro - Fatal Intro by Samar Productions (1995) With X-SID 8580
C64 - Music - Fanta in Space by Fanta (2008) With X-SID 8580
C64 - Game - Rubicon by 21st Century Entertainment (1991) with X-SID 8580
C64 - Music - Contre by Hokuto Force (2023) with X-SID 8580
C64 - Music - Short Intro Tune by Gangstar (1995) With X-SID 8580
C64 - Music - Vintage Pubes by Jammer (2017) with X-SID 8580
C64 - Music - Right In The Night by Hokuto Force (2023) with X-SID 8580
C64 - One-File Demo - Worming Up by Cascade (2023) with X-SID 8580
SPECIFICATIONS
  • Based on Nano SWINSID but completely revisited
  • This is the only SID replacement with perfect dynamic range for the best Audio quality (check the Oscilloscope analysis and Web release)
  • Double led on board with fast 6581/8580 filter emulation selection (hot selection!)
  • Without initial/startup "BEEP" when it turns on!
And that's not all ...
  • Professional & industrial PCB quality
  • Equipped with precision pin headers to plug on your motherboard socket U18 position. Pins are 0.6mm to ensure they do not cause extra wear on your socket. Gold plated to ensure the best possible contact
  • New PCB layout and hardware improvement
  • Remember that normal pin header would damage the socket U18 on your C64 motherboard
  • Paddles and mouse are not supported
PRICE: 29€
Hi, interested pending some more info. Do you have some demos for comparison? Using the usual suspects like lazy jones etc. Some digi sounds. Is it based on the old SwinSID?
Interested in one X-SID. I'd like to know how this differs from a SwinSID Nano. Is it the X-SID prevents audio clipping distortion? Thanks.
The X-SID works like a charm on my breadbin C64 replacing a SID6581 perfectly.
Thank you. Leaving positive feedback.
I am very happy that you also appreciate the excellent quality of the X-SID which guarantees you audio quality without distortion when compared to the traditional Swinsid
Thank you man for the trust and for your feedback..:)
