hi all i just made this as i could not find a full picture guide anywhere
Version 2
here is a more detailed version i have just finished just for cf cards
http://www.mediafire.com/?pr68j1ee03c2b79
here is the only files needed
smartfilesystem which goes in L
sfsformat which goes in C
http://www.mediafire.com/?udwe2sgus26rftg
which consists of
diskpart to clear the cf partitions form windows
how to make a sfs boot disk/adf
how to change hdtools to use uaehf.device
how to add sfsfilesystem to system
how to change maxtransfere and mask for cf
how to partition cf
how to format cf partition with sfsformat
next to do is copy systems to cf when i have time
Version 1
cf/hardrive guide for sfs(smartfilesystem)
http://strohmayer.org/sfs/ AmigaOS 3.x/m68k
http://aminet.net/disk/misc/SFS.lha
winuae
windows sniping tool
publisher
adobe acrobat to convert it to pdf
i hope it helps any one out there with problems
if wanted i could upload the seperate pics on here
any comments or modifications are welcome
thanks for looking john
added from our friend mfilos thanks mate
Version 2
which consists of
how to partition cf
Version 1
winuae
publisher
In order to use a newer scsi.device you just need the new scsi.device (lets say for example in DEVS folder) plus LoadModule tool from Aminet (lets say for example in C folder).
Once you have those ready:
1. You just need the following declaration first thing into your Startup-Sequence:
2. You need to comment your existing SetPatch declaration (by putting a semicolon in front of the SetPatch command - like ;SetPatch.....) and then issue the following declaration instead:C:LoadModule Devs:scsi.device
That's all... you're set :smile:C:SetPatch SKIPROMMODULES "scsi.device" QUIET
