Hey Jon,
If you want to be able to play just about any game from SD on your C64 then the 1541 Ultimate II is the way to go. If you're looking for a less expensive, but still very good, alternative then I would check out Jim Brain's uIEC/SD.
Good luck in your search.
Heather
Yep! I'm excited about his redesign of the daughter board. If you already have a uIEC/SD then you should definitely try to find a 1541U or 1541U-II. It's the only device that is going to give you better functionality than the uIEC/SD.Yeah Jim's uIEC/SD is a very nice devise i'm still learning to use it better
also he redesigning the daughter card here's the site..
http://www.go4retro.com/category/hw/
Again, good luck in the search.
Heather
Thanks for all your posts
Well, will a mmc2iec / sd2iec fit my needs of just gaming from SD?
if you do acquire an sd2iec device i highly recommend downloading CBMCommand @
http://cbmcommand.codeplex.com/
it is an excellent file manager for CBM (VIC20/C64/C128/Plus4/PET) systems, supports sd2iec and will copy to and from d64/d71/d81s on the SD
I have the first Version of the 1541U and it is really a damn good solution, but i also know some games that even don´t work with a 1541U...
If you have some time wait for the final version of the Chameleon...http://www.vesalia.de/d_chameleon.htm
