A while ago for financial reasons I had to let my ACA1232 go so my A500+ has been getting by with just 2mb chip and 2mb fast from the ACA500, whilst the ACA500 gives the A500 a nice little boost and things like the quit key work you don't get the full speed benefits without using Maprom and then you lose 512k of the ACA's Ram, thus leaving you a little short when it comes to gaming.
Well I have a little solution, bought right here on Amibay :smile:
This 2mb upgrade plugs into the CPU socket, so requires that you open you A500 and install it. Since I had my own CPU and did not want the 68010 that these were being shipped with I asked for a socket instead, this is because I use the 14mhz CPU on the ACA500, I've found that the CPU in a socket will touch the Keyboard but I think still the case should just about close. If not some modification will be needed (cut a slot on the keyboard plate) or of course solder the CPU directly to the Memory board.
Memory is added to the free memory pool with AutoAddRam tool by Jonathan Potter, I used address 200000 3ffffe which as you can see add's the extra 2mb Fast Ram.
Show config:
And tested with a couple of multi-disk WHDLoad Games + Preload:
Alien Breed Tower Assult
\o/ Superfrog!
All works great
Show config:
\o/ Superfrog!
All works great
