chris.magson
Hi Peeps,
I'm in one of the far reaches of the world, Namibia, and after quite a bit of deliberation, I finally got to ordering a replacement board for my (un)trusty A1200 with no sound (not a cap problem).
Well I ended up getting it from EBay, from a popular seller, and unfortunately it looks like I ended up with another lemon (a rev 1D1 one)...
Let me explain exactly what transpired - I'm sure someone here will know what it is:
Unpacked, connected keyboard, cf, and ps to board and then to telly via video out. Immediately wb screen looked wonky, with wavey lines running down. Moving the mouse also caused ripples on the screen. Screen was jumping intermittently. I could see enough, sort of, to navigate and open a tune - audio was working!
In about 90 seconds, TV (Sony Bravia) started losing signal (like a faulty rca cable).
I was still troubleshooting, then signal went completely. Total time about 3 minutes.
I lifted the top shield (it was shipped complete with top and bottom shield) and stepped back in shock and awe at the spider's nest under there... OMW! This is the worst cap job I've ever seen (I'm not an electrician - I'm talking about images on the web)
Here it is... please revel in its awesomeness:
The cap on the yellow stalks is only soldered successfully(!) on one side. The other actually has melted plastic shielding holding it on, the wires brushing against the cap terminal.
Is there a record book for the worst 'fixes' ever? This one is surely up there, isn't it?
Anyway, I cleaned it off best I could. Underneath is perhaps the reason for the stalks... 2 1/2 solder pads were missing. In fact, there are gouge marks next to the pads and it looks like someone removed the old caps with a screwdriver, lifting them and the pads.
Unfortunately, it's the worst pads to go... there are no tracks ontop of the board I can bridge them to.
Best I could make out from the remaining via's, I've taken one terminal each of the two the caps to the back of the board as such:
C409 -ve terminal onto C804 (looks like ground side?)
C263 -ve terminal onto R235 (via comes out on the 3 of R235)
(I don't know if it was the right thing to do, but I epoxied those two smd's - on the padless ends - to the board)
Are my modifications Ok or did I gimp it?
I still don't have any video.
I've probed (with 22uF cap inline to telly input) pin 20, and the telly almost wants to show something (no signal goes away), but it's just blankness.
(If I do this on my old, audioless board, I get a picture)
Is it possible U12 is damaged?
I don't have a scope and the telly has a sort of autosensing on the video in, so doesn't show anything making it very hard to troubleshoot.
The board is still working... Cannon Fodder booting off stiffy sounds awesome, but naught to see.
Thank you kindly for any help or advice.
