Closed A600 / A1200 recap service
  • Replies Replies 111
  • Views Views 27014
@steve :-)
pics here bud, A600 recapped (had a bad PSU connector.
@lechuck
PM on the way.
Hi Mike,
Just sent you a PP deposit of 75 pounds for the 3 mobos. You should get the package on Tuesday or so. Thanks in advance for your service!
Regards,
ed...
i will recap your Amiga A600 / A1200 / 4000
Hi my friend.
I have one A1200 dead and an A600 3.1 with ACA620 but EasyNet doesn't work and I don't have any other pcmcia hardware to test it. On another A1200 works fine. I copied A1200's WB to A600 just incase I did something wrong with the settings but no luck. Do you think it is a socket problem?
@crazyegg
working on your boards now - soaking in lemon juice at the mo - they caps have leaked a lot on the 600.
@ taj
working on your boards later tonight - sorry for the delay.
@Acid.
Working on you 600 too.
@VincentGR , im not sure do the pins look bent in anyway? does the easynet work on the 1200?
Yes, pins are OK and it works on A1200. This week I am waiting a pcmcia ram to test if easynet is incompatible with my mobo. I'll notify u and if i have a prob we will discuss if u can fix it. (if u have spare time) thanks in advance. :thumbsup:
@crazyegg
@ taj
@Acid.
:thumbsup: Woo hoo:D thanks Mike, much appreciated:)
A1200 recap
A1200 recap
Just sent you a PM requesting details for an A1200 recap.
Many thanks
New member here. Just wondering if you still have audio caps for the A4000 mobo? I have a Mobo with sound problems and I've been told that a recap might fix it. Are you familar with this particular problem?
Hi
Yes audio problems are usually capacitor faults ..but not always
Yes I have the gear to recap an A4000
Mike.
@taj
all done sorry for the delay all - working long hours :-(
ready for posting...taj
all recapped.
A600
A1200
CD32
Woo hoo!! Will PM later as Im out at the moment:-)
Thank youso much Mike:thumbsup:
@Deanp
Your 1200 is recapped and the indy vision is glued down now too :-)
posting out this week bud - hope the withdrawal symptoms were not too bad :-)
I have some work for you my friend!
I just checked one of my workhorse machines (1D.4) after a long time being laid up and there are signs of cap leakage, it works perfect but I want it saved before something bad happens!
Also have another 1D.4 which I cannot remember the history of, belonged to somebody who had paid Wizard Developments to upgade it, ram board, hard drive with install kit etc. But the custom drive bracket they provided kinda marked the holes a bit. Nowt wrong really just could do with a knowing eye and then some enamel on it. It also failed on me when reading disks so I just left it at that. It has been in my storage for a very long time! I was surprised to find 3.1 roms on it etc.
I do have more but one of these has issues, think it fails after a while. Cannot use the IDE port without it bombing out etc?
Regards J :)
Fantastic job Mike. A1200 arrived today after your repair and all working perfectly. Many thanks for offering this great service.
Hopefully bump into you at Revival in May.
Feedback left
Just wanted to say Mikes work on my 3 Amigas is absolutely brilliant! Prompt turn around of the systems too, in fact he now has 2 more! :thumbsup:
