For Sale Amiga A4000 Reproduction Case Pre-Order Closed
  • Thread starter Thread starter Ordyne
  • Replies Replies 388
  • Views Views 43820
So this is a test of the latest feature request. This makes a change so the drive tray is fastened from the inside of the case. The main advantage of this is that you don’t need to remove your front cover to take the drives out. Just remove the two screws which are now on the inside, pull back the tray to release it from the clip in the bottom of the case and then lift out.
Following photo’s are just from a test.
If you want this feature let me know!
I would like this feature please
Declaring interest in 1 - with all extras.
Honeycomb vented expansion slot covers,
Honeycomb vented Zorro card slot covers
PCB Insulation sheet set,
CF to IDE PCB Expansion slot mount,
SD to IDE PCB Expansion slot mount,
Rear IO sticker
(Marked as sold/completed by Ordyne)
Declaring interest!
I want a black cover, the case and all accessories
in one with beige cover and all accessories
Beige colour with all optional extras and the latest tray feature.
Just a question, but would it at all be possible to get the internal steel chassi (and accessories) painted black as well?
If not, I'll do that myself either way. :)
Declaring interest with the following extras
Rear IO sticker
Zulu SCSI
Rear IO sticker
Latest tray feature
This would be possible but would take quite a bit of work as all the parts would need to be sanded or sand blasted before they could be painted or the paint will not stick properly to the galvanised steel. Cost to paint the full case base and parts would be £100, let me know if you want this doing.
I am planning to powdercoat the whole thing like I did my A2000 build
Yes, please. Thank you!
  1. Boing-ball
  2. Koolvin
  3. Karlosjackel
  4. Xanxi
  5. JazzTrumpetplayer
  6. oggie
  7. Kyle
  8. cv643d
  9. Vampire1200
  10. Ntsimouris
  11. QuarXky
  12. alama
  13. saft6luck
  14. ElectroBlaster
  15. Dale423
  16. Timtheloon
  17. kaosboss
  18. Martin Eugén
  19. ChrisHammond
  20. mirq
  21. Bandaren
  22. ciVic
  23. Woz
  24. k0x
  25. videogeek
  26. qz3fwd
  27. Koolvin
  28. yugorin
  29. crrn
  30. nickrb
  31. Yulquen74
  32. Normski
  33. Cefa68000
  34. wildcopper
  35. mvickers03
  36. Shatush99
  37. johntayloruk
  38. plasmab
  39. nickrb
  40. Szmn
  41. toddbailey
  42. samoht
  43. larsih
  44. kdonat
  45. ctrlbreak
  46. nickrb
  47. wstlr
  48. utukku
  49. Lamaman1971
  50. iluvator
  51. SnowCrash
  52. Duri
  53. ferrumm
  54. Amiga_Poland
  55. GadgetUK
  56. sjwaller
  57. G-linx
  58. dawgtool
  59. Telsar
  60. Sanxion
  61. Travailleur
  62. Gregorius
  63. a1200freak
  64. amienslaver
  65. cemi
  66. Bit-Image
  67. kaosboss
  68. Drewlio77
  69. akira70
  70. tomarkus
  71. sjbwii
  72. VTUEK
  73. patrickgill
  74. luddeprutt
  75. Megatron
  76. tadeo80
  77. Da1ek
  78. cathers
  79. RetroMachine
  80. videogeek
  81. TwinTurboMike
  82. suavek
  83. MarkJPK
  84. saft6luck
  85. andrean
  86. Boing-ball
  87. amigasquirrel
  88. janderson
  89. cdctm
  90. Neztik
  91. steveski
  92. Port89
  93. C16Oli
  94. Megatron
  95. gregvl
  96. Thirty-Thirty
  97. ajwhix
  98. loupsifer
  99. Heizer
  100. Tbsnc99
  101. biaxqr
  102. thiriel
  103. nicholas.j.henning
  104. RichardM
  105. asregg339
