Amiga Error Codes
  • Thread starter Thread starter Geraldine
  • Replies Replies 16
  • Views Views 56327
Geraldine
Re-discovering Amigas after a bit of an absence!
Scotland
Renfrewshire
Here is some error codes I found from the November 1993 edition of CU Amiga. Perhaps some might find them useful :)
GURU CODES
General error codes
01 - Not enough memory
02 - Couldn't make library
03 - Can't open library
04 - Can't open device
05 - Can't open resource
06 - I/O error
07 - No signal
08 - Bad parameters
09 - Close library failed: usually too many closes
0A - Close device failed: or a mismatched close
0B - Process creation failed
Specific Alert Codes
EXEC Library
0001 - 68000 exception vector checksum (obs)
0002 - Execbase checksum bad (obs)
0003 - Library checksum failure
0005 - Corrupt memory list detected in FreeMem
0006 - No memory for interrupt servers
0007 - InitStruct() of an APTR source (obs)
0008 - A semaphore is in an illegal state of Rem Semaphore()
0009 - Freeing memory that is already free
000A - Illegal 68K exception taken (obs)
000B - Attempt to reuse active OIRequest
000C - Sanity check on memory list failed during AvailMem (MEMF_LARGEST)
000D - IO attempted on close IORequest
000E - Stack appears to extend out of range
000F - Memory header not located. Usually an invalid address passed to FreeMem
0010 - An attempt was made to use the old message semaphores
00FF - A quick interrupt has happened to an uninitialised vector
CPU Exceptions
0002 - Bus Error
0003 - Addressing error
0004 - Illegal instruction
0005 - Divide by zero
0006 - CHK instruction
0007 - TRAPV instruction
0008 - Privilege violation
0009 - Trace
000A - OpCode 1010
000B - OpCode 1111
000E - Stack frame format error
0018 - Spurious interrupt error
0019 to 001F - AutoVector Level 1 to 7 int error
Intuition Library
0001 - Unknown gadget type
0002 - Create port, no memory
0003 - Item plane alloc, no memory
0004 - Sub alloc, no memory
0005 - Plane alloc, no memory
0006 - Item box top <RelZero
0007 - Open screen, no memory
0008 - Open screen, raster alloc, no memory
0009 - Open sys screen, unknown type
000A - Add SW gadgets, no memory
000B - Open window, no memory
000C - Bad Stare Return entering Intuition
000D - Bad message received by IDCMP
000E - Weird echo causing incomprehension
000F - Couldn't open the Console Device
0010 - Intuition skipped obtaining a sem
0011 - Intuition obtained a sem in bad order
Graphics Library
0000 - Graphics out of memory
0001 - MonitorSpec alloc, no memory
0006 - Long frame, no memory
0007 - Short frame, no memory
0009 - Text, no memory for TmpRas
000A - BitBitMap, no memory
000B - regions, memory not available
0030 - Make V Por, no memory
000C - (GFX New Error)
000D - (GFX Free Error)
1234 - Emergency memory not available
0401 - Unsupported font description used
Workbench
0001 - No fonts
0001 - WB Bad Startup Msg1
0002 - WB Bad Startup Msg2
0003 - WB Bad IO Msg
0004 - WB Init Potion Alloc Drawer
0005 - WB Create WB Menus Create Menus1
0006 - WB Create WB Menus Create Menus2
0007 - WB Layout WB Menus Layout Menus
0008 - WB Add Tool Menu Item
000A - WB InitTimer
000B - WB Init Layer Demon
000C - WB Init WB Gels
000D - WB Init Screen and Windows1
000E - WB Init Screen and Windows2
000F - WB Init Screen and Windows3
0010 - WBMAlloc
Layers Library
0000 - Layers out of memory
Expansion Library
0001 - Freed free memory
Trackdisk Device
0001 - Calibrate: seek error
0002 - Delay: error on timer wait
Disk Resource
0001 - Get unit: already has a disk
0002 - Interrupt: no active unit
RamLib Library
0001 - Overlays are illegal for library segments
Console Device
0001 - Console can't open initial window
Timer Device
0001 - Bad request
0002 - Power supply: no 50/60 Hz ticks
Bootstrap
0001 - Boot code returned an error
Dos Library
0001 - No memory at startup
0002 - EndTask didn't
0003 - Qpkt failure
0004 - Unexpected packet received
0005 - Freevec failed
0006 - Disk block sequence error
0007 - Bitmap corrupt
0008 - Key already free
0009 - Invalid checksum
000A - Disk error
000B - Key out of range
000C - Bad overlay
000D - Invalid init packet for CLI/SHELL
Alert Objects
8001 - ExecLib
8002 - GraphicsLib
8003 - LayersLib
8004 - Intuition
8005 - MathLib
8007 - DOSLib
8008 - RAMLib
8009 - IconLib
800A - ExpansionLib
800B - DiskfontLib
800C - UtilityLib
800D - KeyMapLib
8010 - AudioDev
8011 - ConsoleDev
8012 - GamePortDev
8013 - KeyboardDev
8014 - TrackDiskDev
8015 - TimerDev
8020 - CIARsrc
8021 - DiskRsrc
8022 - MiscRsrc
8030 - BootStrap
8031 - Workbench
8032 - Diskcopy
8033 - GadTools
8035 - Unknown
Keyboard Caps Lock light
1 Flash = ROM (internal to keyboard processor)
2 Flashes = RAM (internal to keyboard processor)
3 Flashes = watchdog timer (IC 741s 123 or associated circuitry)
4 Flashes = A shortcut exists between two row lines or one of the seven special keys (not implemented), thanks for that Juv!
No Flashes = Main PCB fault
Amiga 1200 & 4000 Screen Colours
Colour Black: Opening Screen Initial hardware configuration passed. Initial system software passed. Final initialisation test passed
Colour Red: ROM error, reseat or replace Kickstart ROMs
Colour Green: CHIP RAM error
Colour Blue: Custom Chip(s) error
Colour Yellow: 68000 detected error before software trapped it (software or hardware error)
AmigaDos Error Codes
Displayed in CLI or Shell
103 - No free store
105 - Task table full
114 - Bad temlate
115 - Bad number
116 - Required arg missing
117 - Key needs arg
118 - Too many args
119 - Unmatched quotes
120 - Line too long
121 - File no object
122 - Invalid resident library
201 - No default dir
202 - Object in use
203 - Object exists
204 - Dir not found
205 - Object not found
206 - Bad stream name
207 - Object too large
209 - Action not known
210 - Invalid component name
211 - Invalid lock
212 - Object wrong type
213 - Disk not validated
214 - Disk write protected
215 - Rename across devices
216 - Directory not empty
217 - Too many levels
218 - Device not mounted
219 - Seek error
220 - Comment too big
221 - Disk full
222 - Delete protected
223 - Write protected
224 - Read protected
225 - Not a DOS disk
226 - No disk
233 - Is soft linked
234 - Object linked
235 - Bad hunk
236 - Not implemented
240 - Record no locked
241 - Lock collision
242 - Lock timeout
243 - Unlock error
303 - Buffer overflow
304 - ***Break
305 - File not executable
Thanks Geraldine, +1 for the Sticky :thumbsup:
@Geraldine
Nice and handy and all in one place :thumbsup:
Stickied
Dave G :cool:
Its my way of saying thanks to Amibay for all the help I have had here in getting my miggys up and running again. :D
can anybody tell me what this likely means then, get it 50% of the time i boot my a500+ ive got nothing in the trapdoor now either
What about the blink codes on an a1200's power led? I only ask because I have 6 short 1 long, and obviously it won't boot. Ironically, it came up on a soft-reset, was working just fine before.
6 or more blinks is usually broken tracks around the battery area after an acid leak
Blinks
1 ROM checksum failure
2 RAM test failed
3 Watchdog timer failed
4 A shortcut exists between two row lines or one of the seven special keys (not implemented)
If you don't mind Juv I will add this "4 A shortcut exists between two row lines or one of the seven special keys (not implemented)" to my original post. Which reminds me, if anyone discovers more error codes, feel free to add them here and I will update my original post ;)
Why bother with such a huge error codes listing?
It would be a lot easier if Commodore allowed her to talk to the user (:nuts:)
add away dear girl add away:)
Does anyone have a list of blink codes for Amiga 3000 power led?
I dont but If you or anyone else finds any, put them here I and I will add them to the first post. :)
