Amiga floppy drives repair
  • Thread starter Thread starter Xanxi
  • Replies Replies 5
  • Views Views 499
Xanxi
Donator
France
Paris
Hi.
I have a bunch of internal or external flakey or non working floppy drives and after seeing some videos i want to carry on repairs myself, including throughole caps replacement.
About the grease for the rail, can i use the WD40 gel Amazon or should i use a silicon grease like Amazon again or anything else (feel free to provide link)?
About caps, is there any list of caps for usual Amiga drives like Chinon and Panasonic or Teac, or ready made sets one can buy?
Thanks for your help.
I always use some white lithium grease on the rails when overhauling disk drives. A small amount applied with a Q-tip (cotton bud) then manually move the heads up and down the rails a couple of times to help spread it and it's job done.
I tend to stay away from the spray types, not easily applied in tight areas without leaving mess everywhere.
I have used all sorts in the past! But I am no expert on this stuff so if it works I am happy.
I use Shaver oil for the head rails and lithium gear grease and sometimes vaseline for the worm gear drive.
All the drives still work too this day!
As for caps, the smallest physical types within spec that I can get away with. I have repaired a few Teac units by laying through holes on their sides where the original
surface mounted cap was. Seems to work ok with bit of hot glue on it maybe.
Lithium grease:
Shaver oil:
Thanks, i'm going to order lithium grease right now.
