Thanks. Will PM you now with info etc..Sure, I can fix the oscillator pads of the CSPPC for you.
I recommend contacting @roy_bates here on Amibay. He is an expert when it comes to repairing monitors and is located in the UK.Hi, I have a Commodore 1084S. It was previously working fine until I removed a Sega Megadrive from the composite at the back to try to attach an Atari 10-in-1 game and now I can’t seem to get it to produce an image no matter what I plug into it. It turns on, but nothing shows on screen. Looking for some help, if possible…
www.amibay.com
that is very kind of you,a moderator has mentioned this person already in pmI recommend contacting @roy_bates here on Amibay. He is an expert when it comes to repairing monitors and is located in the UK.
Filled - several monitors for repair
so,i was asked to look at these,for now i'll give a list of what i have to look at repair wise and opened on behalf of bryan fieldhouse here is the list of monitors,for now as its for feedback purposes and something to look at :) 1 cm8833 mk2 2 cm8833 mk1 1 commodore 1084st 1 commodore...www.amibay.com
Yep, repairing the A3000 motherboard that had such a wide spread battery leak requiring ~100 vias to be reinforced / fixed was an ordeal but got there in the endGot my hardware back. Sorry for the bad condition. That didn't seem so bad at first. Another great job. Thank you!![]()
Board received back all working again. Many thanks to Hese for a fast repair and returnDeclaring interest.
@hese My Cyberstorm PPC/060 appears to be FUBAR. Yep I messed up trying to change out an Oscillator on the PPC side from 60mhz to 50mhz due to instability on the PPC side. Looks like I have used too much heat and damaged the pads on the oscillator holes. Now only get low high x 2 and then looks like it wants to initialise and freezes up. Nothing going through the SCSI. Hopefully you can help fix it again…![]()
Is this the first and only service you have used on this thread?I received my repaired Amiga 4000 mainboard again. Good work and a big thank you to Hese!
I want to add positive feedback but I can't select this thread when adding feedback. Can one of the mods check this please?
Yes. Only the repair of an Amiga 4000.Is this the first and only service you have used on this thread?
