Milesunder
Hello all,
I am looking for assistance and any pointers people might offer with installing OS4.1 on my a4000t. My current setup consists of the following:
a4000t
Super Buster 11
16mb Ram
Cyberstorm PPC with 68060 (Rev1) 604@200mhz 96mb ram
Gotek
SCSI2SD v6
SCSI CD drive
Mediator V1
Radeon 9250 128mb Graphics
Spider USB
Soundblaster
100MB Network Card
Currently nothing on the IDE header except the Terminator.
Using SCSI from the Cyberstorm PPC
Using SCSI 3 to SCSI 2 adaptors on the ribbon cable. With an active terminator then the CyberStorm, Then the SCSI2SD and then the CD with the active terminator pin closed.
I have tried a CF card on the IDE port and have experienced the same issue.
So the issue that I am experiencing is a strange one. Before I start the machine I have configured the 32gb SD card in the SCSI2SD and have followed the guide here to set up the SD card https://grimore.org/hardware/amiga/using_scsi2sd_drives
With the boot floppy adf installed, the CD in the drive and an unconfigured drive in the SCSI2SD the machine will eventually boot into the install screen. There I can configure the hard disk and partition the drive. As far as i can tell I have configured the drive correctly on the cyberscsi.device. The software will install and it states in has installed successfully. However, when I try to reboot the machine will not reboot and just hangs on the Amiga 4.1 splash screen. When I then try to do the reinstall from the boot disk the machine will not boot again. It only gets as far as the splash screen again. If i put a blank disk in then it will go to the config screen again.
If I get to the boot screen and select boot the OS from CD the software will install and run.
I have also tried a SCSI2SD v5.1 and have the same issue.
When I tried with a CF card I did get an issue where it said it couldn't write to the disk. I might try this evening with an IDE 4 port expander see if I get anywhere with this.
Any help or advice would be gratefully appreciated.
a4000t
Super Buster 11
16mb Ram
Gotek
SCSI2SD v6
SCSI CD drive
Mediator V1
Spider USB
Soundblaster
100MB Network Card
