Sold Amiga RGB2VGA Ultimate Line Remover Multi Filter User Switchable
  • Thread starter Thread starter sampedenawa
  • Replies Replies 248
  • Views Views 16423
in 1 piece with DB23
(Marked as sold/completed by sampedenawa)
There could be the remote chance (just to consider all possibilities) your adapter was damaged in transit
and a cold solder disconnected a pin on the filter chip.
Just to exclude the case, you could try to "push down" the chips (pressing them towards the pcb) with your finger (with the adapter connected, no risk to damage anything) and see if the magenta turns into full color or not.
Let me know, just in case it will be an easy fix. Never happened until now, but I want to be sure having considered all possible cases :)
Tested again now, pressing on just about everything on the board. Tried some different settings on the filters as well but no difference.
The picture is perfectly stable, it would be absolutely awesome, if it weren't for the overall magenta hue.
Just for the sake of it I'll try another cable but I don't have one so I need to check with some friends if anyone has a high quality VGA cable.
First task we have is to establish whether if the magenta is due to the fact that your monitor does not support these freqs, or rather the adapter is gone defective (in that case I'll keep it back and repair or switch it for you).
Let me know further tests.
Hello,Without db23 connector
Regards
I need to find someone that has a monitor that's known to support 15kHz so I can test the adapter there. I'll get back on this when I know more.
2 with DB23 please
2 With DB23, if you still have some. :)
  1. pedro.rocha
  2. jamonyorke
  3. hoebedoelu
  4. btp
  5. keiko
  6. larsove
  7. Miru
  8. C16Oli
  9. StompinSteve
  10. softinn
  11. Hirsch
  12. neuron55
  13. Cefa68000
  14. Moomin
  15. noise
  16. rabidgerry
  17. SnowCrash
  18. Ariadne24
  19. Szmn
  20. clockchip
  21. Aeberbach
  22. dabone
  23. ChrisHammond
  24. yeko
  25. dirk.trowe
  26. Reborn
  27. ianoakley
  28. Lakrits
  29. Duri
  30. highpuff
  31. Falcon_11
  32. loupsifer
  33. MolB
  34. AwakeningStar
  35. retrosalvage
  36. silencer_ar
  37. Rostislav
  38. ralphz
  39. tin_
  40. Teabeats
  41. andabata
  42. Ludom88
  43. davide.romanini
  44. Lisko
  45. jsundh
  46. Etosha69
  47. Oldman1000
  48. David123
  49. matt020
  50. Stumpi73
  51. activist
  52. tect
  53. Quasaar
  54. uunek
  55. davesade
  56. RetroMachine
  57. daver
  58. mvickers03
  59. conte0
  60. rnooo
  61. II-IRON
  62. Connair
  63. tom_seddon
  64. jd64
  65. ilooked4u
  66. Feliksas
  67. BuzzBrain
  68. muteki
  69. bfbiii
  70. James
  71. 1infiniteloop.se
  72. markpaterson
  73. zerec
  74. tomarkus
  75. BIG500
  76. rolo9707
  77. olliethebasset
  78. StrongARM
  79. uniquefreak
  80. Thirty-Thirty
  81. spajdrex
  82. globaltrasher
  83. geekdot
  84. DEAT
  85. amigaras
  86. wizzo
  87. Madowax686
  88. codewiz
