Added you to the dedicated thread with instructions !Declaring interest.
Declaring interest in one piece with DB23
(Still 4 adapters available on sale)
View attachment 2479791View attachment 2479792
AMIRGB2VGA ULTIMATE
Reservations (when available):
asking 28€ each plus shipping worldwide (no DB23)
asking 35€ each plus shipping worldwide (with DB23)
AMIRGB2VGA ULTIMATE
is a "revised-revised" RGB to VGA adapter for the Amiga A500-A600-A2000 and A1200-A4000, with unique improvements:
- Fully buffered Composite HSync and VSync signals
- Selectable CSync signal for those lucky guys who own a Sony PVM monitor (or feed a GBS-C converter, etc)
- Impedance matched inputs and outputs
- Fully high quality buffered video signals
- Fully filtered spurious input frequencies: no more vertical bars on LCD screens !
- Four user selectable filter settings: precisely match your display resolution for perfect quality !
- Smaller than the original 390682-01/03 VGA dongle by commodore
User can freely select any of the four low-pass filter profiles, to either match resolutions for maximum clarity and clearness; available profiles are:
- SD -> 9.5Mhz
- ED -> 18Mhz
- HD -> 36Mhz
- FHD -> 72Mhz
THE ISSUE
When connecting an Amiga computer (or in general any computer/console designed to be used with an analogue RGB monitor) to a modern LCD screen with a VGA interface, one can observe the typical 'jail bars', annoying horizontal stripes covering the entire screen.
The VGA input , unlike the scart one, is not bandwidth limited in any way; thus it picks up any spurious noise on the Amiga RGB signals.
More in detail, the basic problem is the VGA monitor: the Amiga video output was designed with CRTs in mind (which was the correct solution at the time); the video bandwidth of those CRTs was something limited to ~10MHz.
Video jailbars artifact are, in the frequency domain, frequency components >28MHz (they come from the fundamental Amiga 28Mhz clock and its higher harmonics) .
Modern VGA/LCD displays, support today video bandwidths of 130MHz and more, so they are able to display these frequency components which take the form of annoying jail bars.
THE SOLUTION
This below is the result of the video filtering and impedance-matching of the adapter:
A practical and effective solution to the issue is to limit the video bandwidth from the source with a proper video amplifier chip with lowpass filter.
The cut-off frequency of the low-pass filter must be correctly calculated in order to eliminate unwanted frequencies, without however compromising the quality and definition of the video information to be displayed.
In the case of the Amiga series computers, it is basically a matter of calibrating the filters for two major cases: OCS/ECS and AGA.
In the first case, filtering calibrated at 9Mhz or 18Mhz is appropriate, while in the second case it is appropriate to increase the bandwidth, filtering around 30Mhz.
The design described here combines in one device the ability to select any of four appropriate cut-off frequencies on the fly, using a commercial chip from Texas Instruments, which performs the function of video amplifier and selectable filter.
The inputs and outputs of the circuit are also calibrated to the correct impedance of the video signals, and the horizontal and vertical synchronisation signals are buffered for maximum possible stability.
Finally, an option has been included to replace the horizontal synchronisation signal with the composite synchronisation signal, so that Sony PVM-type displays or GBS-C-type converters can be connected.
The switchable frequency lowpass filter show the following figures:
Edit:
There's one here, from a Czech user.
It's not mine, so I can't assure anything about it, but worth a try
AMIRGB2VGA ULTIMATE
AMIRGB2VGA ULTIMATE
- SD -> 9.5Mhz
- ED -> 18Mhz
- HD -> 36Mhz
- FHD -> 72Mhz
THE ISSUE
THE SOLUTION
Edit:
Got you !Declaring interest in two pieces with DB23
Added to to the private thread with instructions..Declaring interest in one w/o DB23.
Invited you to the dedicated thread with instructions !Declaring interest.
Declaring interest in 1 piece with DB23
Declaring interest in 3 pieces with connector
Hello. I already have a v3b of this, but was wondering has anyone produced a case for 3d printing? had a look around here and the GitHub page but not found anything. Thanks
Declaring interest.View attachment 2479791View attachment 2479792
AMIRGB2VGA ULTIMATE
AMIRGB2VGA ULTIMATE
- SD -> 9.5Mhz
- ED -> 18Mhz
- HD -> 36Mhz
- FHD -> 72Mhz
THE ISSUE
THE SOLUTION
Edit:
Interested in 1 piece with DB23. Ship to Italy. Thanks.
| Nick | Reserved | $ | Status | Country |
| andabata | 3 WITH DB23 | RESERVED | ||
| davide.romanini | 1 WITH DB23 | RESERVED |
At the moment I am still gathering reservations; a minimum number of requests is needed before starting a production lot (fixed costs don't make bearable to produce quantities < 15-20 pcs)Hello how to proceed to pay?
Ludom88
Have a iiyama as4821dt, https://icecat.biz/fr/p/iiyama/as48...+19+inch+tft+1280-1024+black-84485.html#Specs
is it ok with this screen?
