For Sale AMIGA VGA ADAPTER --> DELUXE + EXTREME EDITION! (VLR buffered in DB23 HOOD with micro PCB). For all AMIGA platforms.(Also for GBS8200/OSSC)
  • Thread starter Thread starter axel81
  • Replies Replies 137
  • Views Views 12614
axel81
Italia
Monza Brianza
IT'S TIME FOR DELIGHT
  • New VGA Adapter version with miniaturized VLR (vertical line remover) in original HOOD DB23!...and compatible with any AMIGA.
  • No shell cut off ... no connector cut off : all original!
  • Usable also with Upscaler/OSSCV/GBS8200 (read info on the bottom) **
NEW EXTREME EDITION AVAILABLE! Now with DB15 HD inside
20220421_164301_edit (FILEminimizer).jpg 20220421_164252_edit (FILEminimizer).jpg
...This is the best Amiga RGB-VGA adapter on the WEB...
What's new?
  • New VGA Adapter miniaturized in original DB23 HOOD with original DB23F and VLR system!
  • VLR system (vertical line remover) that fix vertical line on your LCD monitor/TV 15KHz horizontal compatible
  • VDE system (video distortion enhancement) that improve video quality and NO background noise
I have read and received inquiries in this time since I successfully put the VGA adapter made with the original DB23 connector on sale. To date almost 800 units have been sold between Ebay and retrogamer forum and other online channels. Great success and appreciation for having an original DB23F connector on board (not a cut DB25)
Many of you were bored by those annoying vertical lines that arise with the use of LED matrix (example Benq BL702A). This LCD monitor is one of the few monitors that allows you to almost completely obviate these "vertical bars" by adjusting the various parameters of meù such as the "pixel clock". But not all LCD monitors / TVs (compatible with 15KHz) have this feature, so the result is images with these annoying vertical stripes which are really bad.
From today this will finally be just a distant memory.
With the new VGA ADAPTER with VLR+VDE system you can use any monitor / TV (compatible 15KHz) without having to change the image parameters (pixel clock, etc.). Furthermore, the saturation / color /distortion of the RGB components is improved with the new adapter (you can see it in the second photo VDE system )
This is the ONLY VIDEO ADAPTER realized on PCB board (buffered) + vertical line remover (VLR) made with ORIGINAL DB23 Female and its HOOD!
>>> ...take your time and check all the pictures...check the real and original DB23 PIN with its HOOD<<<
COMPATIBILITY
This adapter allows you to connect a VGA/SVGA* or Multiscan monitor to your Amiga RGB port.
This is fully buffered + VLR system for all Commodore Amiga platforms (500, 500+, 600, 1200 or "big box" Amiga systems like A4000..)
This adapter allows you to use the following display modes:
  1. DBLPal
  2. DBLNTSC
  3. Euro 36Hz and 72Hz
  4. Super72
  5. Multiscan/Productivity
  6. VGA Only
IMPORTANT NOTE:
*SVGA monitor must be able to sync the Amiga's 15Khz signal (most CRT monitors have no problem doing this). Some LCD monitors such as DELL U2410 or BENQ BL702A sync down and support 15Khz- check your monitor specifications for more information.
If your monitor does not support 15KHz, then you will not get a picture until the software drivers are installed and workbench is loaded.
PRICE
Deluxe --> 38€ + shipping
Extreme --> 45€ + shipping
**OSSC / GBS8200 CARD / Upscaler COMPATIBILITY**
YES,it is compatible with OSSC / GBS8200 / upscaler in general
The only thing is that you have to tell me if your OSSC manages the separate synchronism (V + H) or the combined one (C-sync).
DEFAULT CONFIGURATION is "V + H SYNC" but I can set it up for "C-SYNC"
