For Sale Amiga VGA adapter Xtreme! 2.5cm!With original DB23 female and Sync selector for GBS8200/OSSC
  • Thread starter Thread starter axel81
  • Replies Replies 64
  • Views Views 5141
axel81
Italia
Monza Brianza
NEW AMIGA VGA adapter is --> Xtreme (only 2,5cm!)
Xtreme is:
  • The best and smallest Amiga RGB-VGA adapter on the WEB..only 2.5cm!!Made with original and genuine D-sub connector 23 pin female
  • With Xtreme takes less desk space behind AMIGA
  • With Xtreme you can choose Sync position! (V+H or Csync for OSSC/GBS8200 application)
Xtreme adapter version available
  • Xtreme unbuffered-LC version for A500 / A500+ / A600 / A1200 (without sync selection,fixed with standard V+H) 12€ + shipping
  • Xtreme unbuffered version for A500 / A500+ / A600 / A1200 (with sync selector, V+H or Csync) 13€ + shipping
  • Xtreme buffered version for ALL AMIGA COMPUTERS (with sync selector, V+H or Csync) 16€ + shipping
COMPATIBILITY
This adapter allows you to connect a VGA/SVGA* or Multiscan monitor to your Amiga RGB port.
This adapter allows you to use the following display modes:
  • DBLPal
  • DBLNTSC
  • Euro 36Hz and 72Hz
  • Super72
  • Multiscan/Productivity
  • VGA Only
IMPORTANT NOTE:
*SVGA monitor must be able to sync the Amiga's 15Khz signal (most CRT monitors have no problem doing this). Some LCD monitors such as DELL U2410 or BENQ BL702A sync down and support 15Khz- check your monitor specifications for more information.
If your monitor does not support 15KHz, then you will not get a picture until the software drivers are installed and workbench is loaded.
Edit:
Are 3D printed case designs available for this board? Also, is there a benefit of this going into a CRT if I'm using SCART into an OSSC already?
3D prinbted case --> not still available
That is VGA adapter. Does your CRT have a VGA input? Remember that it must be 15KHz compatible
Officially declaring interest, agreed on shipping fees. Thanks. Will respond via pm after declaring interest here.
The device is very good and only 2.5 cm, but I have a question.
Will you design this adapter in a housing?
because it doesn't look very aesthetically pleasing at the moment
Hello
It hasn't been done yet...but you can make a shell with a 3D printer.
You would need to have a design for a 3D printer. Someone would have to design it.
The print itself is not a problem...
