Booting without Startup-Sequence
  • Replies Replies 7
  • Views Views 1745
fitzsteve
Retired Slacker
Assistant
Sevenoaks
Hi!
I want to flash my CSPPC to test with the GREX which involves booting without startup sequence to use the flash tool.
I was able to complete the procedure on my CSMkIII without issue but with the CSPPC when I pick 'boot without SS' from the early boot menu it takes me to the Kickstart splash screen instead of a command prompt as expected.
I'm a bit stumped to be honest :sos
Any help appreciated!
ps. I double checked the CSPPC config menu and 'Maprom' isn't enabled...
---------- Post added at 12:16 ---------- Previous post was at 12:11 ----------
Just tried another floppy drive and it does the same thing (just in case that was the issue) :coffee:
You still need a bootable volume, even if there's no SS. Do you have something bootable in there?
Hey Steve,
I don't know if this would work but could you make a bootable floppy without an OS on it to give you an initial prompt and then switch to your flash tool?
regards,
Ed.
Andy is right on this one.
Just make a bootable disk with the required files on it and just boot without ss :)
Thanks guys, I put a CF on the IDE and disabled it at Startup, got the prompt this time and CSPPC is flashed :thumbsup:
Hi Steve,
I've flashed my CSPP's few times to test different firmware revisions. All times I used a bootable FDD with the FashUpdate inside.
Just to comment... all times I needed to use the /FORCE option. Without that, the update don't work for me.
Also try to flash without the GREX, after the update you can install the GREX again.
I hope this help :)
All the best
---------- Post added at 06:32 ---------- Previous post was at 06:28 ----------
Hi Steve
Too late from my side, my friend :picard
Sorry :picard
Hi Pablo, no worries my friend. I didn't need to Force, both times flash ok :)
Did you remember to disable the SCSI (holding S on startup?) BTW I didn't have GREX connected, just CSPPC & FDD, not even a daughter board!
Hi Steve,
Yes, I have tried everything, but no way...... :blink: Only with the FORCE option works fine on both CSPPC's (one untouched, the other upgraded).
Glad to "see" your CSPPC is updated now :thumbsup:
My best wishes as allways :)
