ACATune - adding it to startup-sequence
  • Thread starter Thread starter TroelsDK
  • Replies Replies 65
  • Views Views 28828
It might be worth cleaning the cf card to have a complete fresh start. Ensure your cf card is connected to your pc.
On your pc type "diskpart" in the start prompt.
Then "List disk"
"Select disk n"
"Clean"
"Exit"
where n is your disk number. Ensure disk n is your cf card by cross checking its documented capacity. DO NOT CLEAN YOUR PC HD!
Once you've done this go into winuae as administrator, mount your cf in winuae by adding it as a hard-drive, partition your cf and set max transfers.
Quick format the partitions and then copy your system hdf to your primary bootable partition.:) Test in winuae to ensure it boots ok
Then "List disk"
"Select disk n"
"Clean"
"Exit"
This I did...
This I can't do... It's not reading the card i UAE
Can you be more specific, you mean when you click on add hard-drive your cf card is not appearing on the drop down list?
Presumably your cf card is recognised on your pc? What make card is it and what size card is it. (Also just as an extra warning do not insert >2gb cf card into pcmcia amiga slot as increased risk of corrupting the card)
OK mate I appreciate your help, and tomorrow I will shoot a movie of the hole deal and post so you can see the problems. I'm to drunk and to busy beating my friends in bomberman right now :D
:) ah bomberman/dynablasters, at its best as a 5 player on the amiga. We used to play at uni, especially after the pub!
Great fun when someone has collected many bombs and become pretty powerful and then somebody else gives them the dropping bomb disease:lol:
Yes Dynablaster on Amiga with 5 players is awesome! We played it here at my place on our little gettogether in March :) Last night it was Super Bomberman on the SNES though... :whistle:
OK I filmed some parts for you, maybe you can make something out of it... (sorry for the shaky cam, I'm a bit hungover :lol: )
Here is setting up the CF-card
Here is failure to boot CF-card
And here is my working systems CF-card booting, just to show that the USB-reader works and that winuae work
Any ideas what could be the cause?
Again winuae had no problems booting the CF-card(s) before I changed the MaxTransfer value. And if I set up the CF-card(s) without changing the MaxTransfer that won't work either now... I write card(s) because I have done this with 3 different cards.
0x1fe000
There are 3 zeros!!!
0x1fe000
I actually wrote 3 zeros the first few time as you wrote but it was the same... nothing happened in winuae... I only changed it after some others said that I should try with only 2.. I have just setup one of the other cards with 3 zeros just to be sure.
And did you remember to hit Enter after each MaxTransfer?
Yes I did :thumbsup:
You have the 1200 roms set up on winuae?
and.. SCSI_DEVICE_NAME=uaehf.device
What make card is it (prefer trasncend 133x) and what size?
yes, you must change it to that, press enter to make it stick:)
I think this may have been the problem
OK when you first add your cf as hard drive make sure it is as on UAE (if this doesn't work try IDE0 or IDE1)
What a saga lol
What a saga lol
Set to UAE (by default) nothing happens
Set to IDE0 / IDE1
System boots up, but no sign of the CF-card
Keep to UAE
click on change drive type and then define new drive, make sure you are doing all this after you have changed Scsi device= uaehf device (I think you change that by right clicking and then info/properties)
Keep to UAE
But after I changed it to "SCSI_DEVICE_NAME=uaehf.device" I can't click on "change drive" (see photo)
I changed it to "SCSI_DEVICE_NAME=uaehf.device" on the install3.1 adf and now I can see the CF-card on winuae
I tried a fresh install of CWB but still can't see the CF-card together with the System.hdf...... :overactor:
Wait!! I think your system.hdf will be the resident dh0! So you cannot copy from dh0 to dh0... so it won't see your cf. Rename your primary bootable partition as dh1
Do not call it dh0, it will confuse wb. If you call it dh1 you will be able to find it in dopus and then copy system.hdf over to it. (I always call my primary bootable dh1 temporarily and change it over to DH0 at the end when its in the 1200.)
Don't forget to quick format your other empty partition (you may need to add more memory in winuae for this - just slide the memory bar over)
I think you should be sorted now :lol:
