It might be worth cleaning the cf card to have a complete fresh start. Ensure your cf card is connected to your pc.
On your pc type "diskpart" in the start prompt.
Then "List disk"
"Select disk n"
"Clean"
"Exit"
where n is your disk number. Ensure disk n is your cf card by cross checking its documented capacity. DO NOT CLEAN YOUR PC HD!
Once you've done this go into winuae as administrator, mount your cf in winuae by adding it as a hard-drive, partition your cf and set max transfers.
Quick format the partitions and then copy your system hdf to your primary bootable partition.
Test in winuae to ensure it boots ok
Then "List disk"
"Select disk n"
"Clean"
"Exit"
