Closed Brand new Commodore 64 keyboard brackets - pre-order for 1st batch
  • Thread starter Thread starter V-12
  • Replies Replies 63
  • Views Views 9035
For all current and future buyers: download manual in English language HERE <-Click (.pdf file).
The manual shows step-by-step explainations of installing the brackets. Including also more pictures.
Items received, looking great, positive feeback left :)
Thank you for feedback. Also feedback left for you, thanx!
EDIT. Also received feedback from ajk and left feedback for him, many thanx. :)
Declaring interest for 1 set of brackets for short motherboard + 1 set of brackets for long motherboard. Thanks!
Declaring interest in 1 set of brackets for long motherboard + screws. Shipping to Ireland.
I want to fit a motherboard from an old c64 breadbin into c64 II case.
For all future buyers who wants brackets for use with Ultimate-64 board. From what I have known, the original sized right bracket may be problematic with Ultimate-64 board. I have to confirm that so if you wants to order brackets for Ultimate-64 board, please wait a while before I will get my own Ultimate-64 and make final tests. :) Thank you!
EDIT:
I had some discussions with users and also chatted with Gideon and there is temporary solution for installing right bracket:
You have to move the right bracket one step to the left and install it with the 2nd left hole of the keyboard. Next you have to put something under to reduce free space between bracket and down part of C64C case. We will think about solution to have possibility to have bracket installed exactly on the right side of the board, so be patient. :)
Declaring interest in one set of brackets to use with Ultimate-64. V-12, Have you received your board? :)
Thanks.
Andre
Parcel received. Great quality product. Positive feedback left.
Now I can have my C64 motherboard in C64C case!
Parcel shipped, thanx!
Thank you! Also positive feedback left. Enjoy!
Thanks.
Andre
Hi Andre!
Nope. I missed unfortunately first preorder and waiting for second.
As I've mentioned above, the right bracket doesn't matches exactly the Ultimate-64 board. It's perhaps because there is a keyboard adapter nearly the joystick ports (acutally Gideon didn't explained me what's the matter of problems with installing right bracket on the board - this is my suppose).
So if you want to use the bracket, you have to move it to the next hole to the left (keyboard has more holes in the upper part) and put something under to reduce free space between bracket and down part of C64 case. It can be anything, like small part of the wood. See pictures below to explain what's the problem.
I will think about solution (perhaps will project new brackets exclusively for Ultimate-64) if I will get my board. But still you can use standard brackets with every kind of board ;)
If you are still interested with standard brackets, let me know :)
Hi V-12 :) At the moment I don't have neither the Ultimate 64 nor the case yet, unfortunately :( I'm just carrying on with the job... I guess also the brackets on sale on Pixelwizard retro shop are not compatible... I think I'm going to wait you to receive the U64 to get the right (modified?) ones. Thanks! ;)
Hi V-12,
Recieved my Ultimate 64 board last Saturday from Gideon himself.
The Original brackets don't fit, the one on the left is ok when you fill the hight of the pcb with little rings.
But the one on the right is a problem, hope you can make a custom bracked that will fit
