Caps caps caps - capacitors , ultimate list?
  • Thread starter Thread starter mjnurney
  • Replies Replies 69
  • Views Views 6771
you're right, 16v is definitely too low
but 25v? i thought the voltage is between ±3-8v
like i found on this nice website here
so +8 + |-8| = 16v
16v x 1.50 = 24v
or am i totally wrong?
anyway, 35v or 50v will work
what bipolarized capacitor you would recommend?
cheers
22x35 or more voltage.
Of course we are talking about an output of 8Vpp* here, but the circuit is -12+12V, so at least (in theory) something circa 36V is required.
Better safe than sorry.
*8Vpp ~= 2.83Vac RMS
On A500+ Rev 8A.1 :
C303 : 35V 22µF
C304 : 35V 22µF
C306 : 50V 10µF
C324 : 35V 22µF
C334 : 35V 22µF
C401 : 10V 1000µF
C402 : 10V 1000µF
C307 : 10V 1000µF
C712 : 50V 10µF
C811 : 16V 100µF
C812 : 16V 100µF
C813 : 16V 100µF
C814 : 16V 100µF
C815 : 16V 100µF
C816 : 16V 100µF
C821 : 50V 47µF
C822 : 50V 47µF
Total :
3 x 10V 1000µF
6 x 16V 100µF
2 x 50V 47µF
4 x 35V 22µF
2 x 50V 10µF
I hope this is the right thread... Where can I find a list of Professionals who can recap A1200 motherboard?
Thanks in advance.
services
services
You can look in section "want to sell" "services" Good luck mate.
https://www.amibay.com/forumdisplay.php?147-Services
Thank you, I've missed that!
"Good luck" because recapping is a dangerous thing? :huh:
I've started using these for the audio outs on A600s. C334 and C324. Probably good for equivalent spots in all AGA machines too.
http://uk.farnell.com/jsp/search/productdetail.jsp?CMP=i-ddd7-00001003&sku=1843167
I no longer think there is a need for non-polarised caps in these positions but as you can see below these are about a billion times easier to solder into that tight position without damaging connectors and should last as good as forever.
You do know that Ceramic SMD capacitors are mircophonic, so they can not only start "playing" the music themselves, but loud noises and vibrations in the room will be added to your audio output and mess up the sound.
They also tend to fail if they get flexed and that part of the PCB (being so close to all those sockets) probably flexs when you plug things in.
Bryce.
A1200 rev 2B ceramic caps
I need to replace c211 c212 c213 smd ceramic caps,on the schematics are 0.22μF but the voltage isn't specified,there is a complete list of these ceramic caps with full spec?
Measure the voltage across the existing ones and multiple it by 2.
Bryce.
Gesendet von meinem Motorola DynaTEC 8000X mit Tapatalk 2.
Done,all others caps measure 5 volt,these 3 measure 2 volt...perhaps the problem is elsewhere.
the four through hole electrolytic caps are a bit of a pain as there is not much clearance between the lead and the hole so when removing them its best to use a powered solder sucker, or a good quality manual sucker, again these pads will burn off if too much heat is applied so be careful, use plenty of flux
The smd electrolytics behind the keyboard connector can be a pain to get the iron onto. Be careful not to melt the connector in the process.
Bryce.
CD32 recap
CD32 recap
Am new to these boards but have recently rekindled my love for all things Amiga by buying a CD32. I got it for £X.xx because it has a sound issue (crackling sound) and I took a punt and had a go at replacing the incorrectly aligned epectrolytic capacitors. I have done this (though I am a complete novice and whilst they seem to be seated okay I am not sure). I cant see any obvious blown capacitors but was wondering if there is anyone on here near Birmingham Uk that coukd recap/repair as necessary.
I'd like to add my shopping list for my C128D power supply that Bryce taught me how to replace. top man !
3x 10v 2200uf 16mm Panasonic 2200µF 25 V , FR Radial Series 10000h 16 (Dia.) x 20mm RS Stock No.708-3787
2x 35v 470uf 16mm Vishay 470µF 63 V 136 Series 10000h 16 (Dia.) x 25mm RS Stock No. 484-6478
1x 10v 1000uf 13mm Rubycon 1000µF 35 V YXF Series 10000h 12.5 (Dia.) x 25mm RS Stock No.191-7870
1x 400v 100uf 25mm Nichicon 100µF 450 V GR Series 10000h 25 (Dia.) x 40mm RS Stock No. 739-5844
1x 400v 47uf 21mm Nichicon 47µF 450 V GR Series 10000h 22 (Dia.) x 30mm RS Stock No. 714-9335
2x 50v 4.7µf 3mm Rubycon 4.7μF 200 V dc LLE Series 12000h 6.3 x 11mm RS Stock No. 767-2794
1x 16v 470uf 12mm Rubycon 470µF 50 V YXF Series 10000h 12.5 (Dia.) x 20mm RS Stock No. 224-4404
1x 35v 47uf 6mm Rubycon 47µF 35 V YXM Series 10000h 6.3 (Dia.) x 11mm RS Stock No. 704-8074
2x 16v 47uf 6mm Rubycon 47µF 35 V YXM Series 10000h 6.3 (Dia.) x 11mm RS Stock No. 704-8074
Gilly
