Hi Folks!
Over the weekend whist I was at Revival my CD32 Motherboard was delivered fully re-capped so yesterday whilst rebuilding this lovely CD32 I took some pics, which of course I'm going to share with my Ami-Friends
So here is the Motherboard after unpacking, as always mjnurney has done a wonderful job.
And with the shield removed, this will be discarded as I'm fitting my Indivision AGA MkII, as you can see Mike has also desoldered the RF modulator for me so that I can mount the HDMI adapter here:
Here is the Indivision in place:
Kipper2k's HDMI adapter is a perfect fit
Here she is inside the bottom case with my SX32 connected. The SX32 clears the Indivision no problem but the connector on the Indivision does get in the way a little...
My SX32 has 8mb Fast Ram and 2gb CF card on the internal IDE.
As you can see, the case closed - no problem!
Made to measure!
Rear ports on the SX32:
First boot the SX32 wasn't detected, but nice to see the splash screen
After all connectors cleaned she's booting up just fine
I'm using an AT PSU with Amigakit's adapter, for the Keyboard I'm using a Lyra adapter.
I'm running Classic Workbench Full with mfilos' Magic Workbench Icons in SuperPlus 800x600 via the Indivision
I like the way you can customise the title bar with Scalos
And of course WHDLoad installed
Beautiful clear image over HDMI on my TV:
I'm running the original Indivision Core so my image is to the right slightly but does not bother me, the image is otherwise perfect
Thanks for looking
Made to measure!
Thanks for looking
