Closed CDTV SCSI Adapter SCSI2CDTV
8 Bit Dreams
8 Bit Dreams
Donator
Germany
Bavaria
ALL ADAPTERS ARE SOLD OUT!
NEXT BATCH IS NOT PLANNED!
Hello Amigans,
offering here some ready built and tested SCSI units for Amiga CDTV Computers designed by Matthias Heinrichs
Limited batch of 6x
This is a redesign of the reference SCSI-Module for the CDTV from Commodore.
It also works in an A570, but sticks out at the end.
It adds an Autoboot SCSI-Controller to your CDTV with one internal 50-pin SCSI connector.
The driver is already included in your CDTV-ROMs. The use of Version 2.30 ROMs is strongly recommended but V1.0 ROMs work too.
An unpatched system supports hard disks up to 1GB
Please check this thread:
http://eab.abime.net/showthread.php?t=33675
Your CDTV
still boots from your CD-Drive first, if a CD is present, if no CD inserted - will autoboot from SCSI!
Works with SCSI2IDE-Adapters too. With IDE-CF adapter you have a very silent retro-Media PC!
To set up SCSI Drive:
You can set up the hard disk via the regular HDToolBox (scsi.device) or better using the HDInstTool from the aminet.
There will be no special installation disk. You can use the a590-ones as a basis.
Asking 35€
30€ paid using Friends/Family option
or by adding 4% PayPal fees if sent as payment
Shipping around the globe is 8,50€ tracked (5,50€ in Germany)
will combine shipping if more items are ordered
IMPORTANT !
Please be very carefull by installing it - check correct orientation!
On CDTV all chips need to face bottom, on A570 Chips are in upper position!
50 Pin IDE Ribbon is NOT included (may be ordered separetely if needed for 7€)
Please declare Your interest if needed
-Your 8 Bit Dreams
Interested, if this allows using drive bigger than 1gb on 3.x/2.30 roms.
Well, it is definitely doable, just need to research how , i do remember there was an instruction one EAB, will try to find it
Interested for my A570. Will send a PM.
G.
Sending out payment info
Added EAB link into first post where large drive support is described.
Also added new photo
Thanks for the link mate :-)
I Confirm my interest.
I am going to try 3.x + 2.30 + PFSAIO 3.1 and its direct SCSI.
can the rear cover be installed with this card fitted?
declaring interest
thanks for declaring Your interest,
Do You need also 50Pin flat ribbon?
Sending out payment info now
PS
rear cover can be closed without any problem, card on my picture isn't fully inserted , took that picture to show proper orientation of the card
regards,
-Viktor
payment received from user
prosonic
for 1x SCSI Adapter
5 units left
Parcel to user
prosonic
is on the way, please check PM for tracking info
One unit is reserved for user
roc
Deal with ethan wasn't sucsessful -
4 units left
Thank You very much guys, positive feedbacks exchanged
PS
noticed that almost half of transactions don't get feedbacks anymore, thats sad,
PPS
also got question about jumper:
it is here to switch between 7Mhz and 14Mhz (14Mhz may or may NOT work on some CDTV's)
other jumper is to disable SCSI (You can mount a switch on, and feed it out of the case)
thank You very much for supporting my hobby! :thumbsup:
My hobby is nothing special - i love soldering..
It's my way to relax
