Just as the title suggests, has anyone tried to put these two together and if so what barriers and problems have you faced and what workarounds have you found?
The A1200NG motherboard fits into original Commodore 1200, Escom 1200 and reproduction desktop cases. The ports align with the holes in the case using the supplied backplate.
Hey, thank you for the reply!
Yes absolutely, that has been my thinking too.
However, I'm concerned about the power supply since its different from a standard Amiga 1200, and I think the A1200NG comes with a power brick which I'd rather have an SFX power supply...
The other question is around the on/off button on the case - which in a way is also related to the above.
In my Checkmate case there's a impulse switch in the front and a board that adapts an SFX supply to A1200, then there's a small lead that loops out of the case and into the A1200.
