I am looking for a pcmcia network card for my a1200, but NOT one that uses the 3c589 driver, but rather a cnet based one. I am hoping this will help with a minor issue I am having.
Cheers
Cheers
Er, no....I have several of those.Are you looking for the one that uses the 3c589 driver?
The OP’s original statement was:hehe made you edited two minutes ago![]()
Good luckCheers - PM replied and funds sent!
@All - yes I know this is not the cnet wired card I was originally seeking, but it might still resolve my problem - only time will tell.
I am having a very specific issue with Supercars 2 AGA (ie the one released in the last few years over on EAB). This is that although WHDLOAD closes down the network (I use roadshow), the game crashes after a few rounds anywhere between round 2 and 6 usually. If I remove the PCMCIA card before running the game - no crash.Good luckIf this doesn’t work, then would recommend looking for a 1D1 rev board
As soon as I did that, my issues were solved.
The specific issues I was having on a 1D4 was when using the network and started to browse sites the Amiga would lock up. Not the issues you are having. I had tried Cardpatch and Cardreset off Aminet in my startup-sequence as well as a Gayle reset adapter. Then when I swapped over to a 1D1 revision, issues went away.I am having a very specific issue with Supercars 2 AGA (ie the one released in the last few years over on EAB). This is that although WHDLOAD closes down the network (I use roadshow), the game crashes after a few rounds anywhere between round 2 and 6 usually. If I remove the PCMCIA card before running the game - no crash.
This game has a lot of sentimental value to me and because of the case I am using one of my amiga's in, removing the PCMCIA card each time just for that is a pain. The game works fine on my desktop amiga (using a pci network card) and on my wedge a1200 I can just slide the card out.
I was hoping that the cnet based card might not have this issue.
