Closed Commodore floppy drive to USB adapter (mini xum 1541)
  • Thread starter Thread starter ajk
  • Replies Replies 338
  • Views Views 65815
@uunek
Package is in the mail :)
Also sent a second package to leof as agreed in PM (soldering disaster).
Declare interest.
1x Complete device
And PM sent
EDIT: Payment done.
@catclou
Are you still interested or should I remove you from the list?
Adapter received a while ago but had no time to test and enjoy it.
Everything worked perfectly.
A nice piece of hardware.
Thanks a lot my friend.
Hello do you have and of the fully assembled units left and will you dispatch to the UK
Cheers
I have received my unit a long time ago. Working fine and as a matter of fact I am using it to dump all my C64 disks for Disk Dumping December. Thanks!
Finally got around to assembling mine but I couldn't get it working with the latest V07 firmware in the OpenCBM archive. I ended up having to use the firmware-update v06-reported-as-v07.hex file that mcleod-ideafix posted earlier in this thread in order to get it working. Would someone please point me to a copy of the V07 firmware that someone has tested on this device? The LED doesn't even light up with the firmware in the OpenCBM package.
Thanks!
Heather
Hi, this is the exact package I have been using to flash all the ones I built: http://ajk.pp.fi/xum/opencbm-ZoomFloppy-2.0-i386.zip
Also, here is how it shows up driver-wise in Windows 7 at least:
It looks like the same package I tried before. Still, I tried the firmware in the file you provided and it doesn't work. The device is detected properly but I only get errors whenever I try to do anything.
Any other ideas? I'd hate to be limited to an older version of the firmware.
Thanks!
Heather
Hmm. Not really :( I did get all kinds of errors with the first IEC cable I had, when I swapped to another, everything started working. Maybe that is worth a try.
BTW was the driver the same as in the screenshot I posted?
