I was inspired by some Gotek -floppy installs shown here, and after restoring my slimline floppy. I though way not and starting to find a proper location for the Gotek. After some time I did found the best place giving me much free space in side my A500 --- below the floppy!
The Gotek had to be striped of some not needed components and remount of others, to slim it even more. A plastic sheet and a small stand off was needed to give isolation and clearance to the flywheel on the floppy. I did have a old hole from a slide-switch that fitted perfect for the USB outlet. A vero-board assembly with USB, buttons and pin-header was maid and hot glued in place. A new floppy cable with three connectors and a breakout of drive select 0 was made. I have a kickswitch so its selector switch had to be replaced so both drive and kick select could reuse the hole for the old kick select switch. Had two micro slide switches in the djunk-box, them did I place on a small vero-board and with pin-header connectors on cable for disassembly reasons. The setup no looks like a oversized 2way DIP-switch unit from the outside. And when top cover is on you can´t see direct that there is a Gotek inside sins I do not have a display.
Hope you enjoy my different setup of the Gotek drive.
