Gameboy Pocket
This is the more rare (I think Japan only) off white/grey model which is designed to look like the original model Gameboy including red buttons etc.
The screen is damaged beyond repair
The contrast dial is faulty - Turns fine but doesn't work very well
The battery cover is missing
The screen lens is damaged - Can be used but previous owner stuck it on with glue and it ruined the grey print on it
Battery terminal has some corrosion. Will run of an AC adapter but had no luck with batteries
The case is yellowing and could do with a retrobrite - I did this about a year ago and it looked great but it did not last.
I have tested it with a good screen and it loads games fine, sound works fine and controls are good but like I said the contrast dial is faulty, so its a bit of a pain to adjust the contrast though it can be adjusted with patience. No missing screws.
I'm looking for 10 Euro + P&P or swap with a couple of Gameboy (GB/GBC/GBA) games or NES games (NTSC or PAL)
