going crazy for sysinfo..
  • Thread starter Thread starter unaccesso
  • Replies Replies 10
  • Views Views 9979
unaccesso
Italy
rome
Hello Amyfuns!
going crazy to found "sysinfo.adf" working for my a500.
i found file in .lha compressed format and 'm desperately trying to convert to .adf with winuae but nothing to do it in anyway. can someone tell me where i can found sysinfo.adf, or convert this archive to an adf file?
Thanks in advance!!:thumbsup:
p.s i don't have an HD so i can install, ideal would be a bootable sysinfo.adf, or bootable from WorkBenck
Why don't you just create a blank disk using Winuae, format it and then unlha sysinfo into the blank disk. The disk will be an ADF.
The file you attached is Syssppeed i think not Sysinfo
Edit: You could also copy lha + the sysinfo.lha (whatever) file onto a PC formatted 720k disk and if you have WB3.x or Crossdos you can read it on the Amiga, and unLHA it using the Amiga.
yes i try, i create two disk:
1) contain sysinfo + install
2) only sysinfo
no one working.. two days i'm trying, pheraps i'm stupid but something goes wrong
How about this:
http://janeway.exotica.org.uk/release.php?id=23141
You will find Sysinfo along with several other utilities pre-packaged as an .ADF file. Version 3.18
Okay, after posting this, I copied the .ADF to my Gotek drive and the first thing that happened was that one of the other programs that came with the ADF would boot and cause problems (Nuke). So hold down both mouse buttons and select boot from hard drive to get past this.
