Does this firmware allow you to use the drive A and B slots in the Atari ST version of the HxCFloppyEmulator Manager at the same time? So when rebooting you have access to both drives? Or can you only use the drive A slots?
If Atari ST/STE firmware is now possible, do you think other machines that the HxC support will also be possible on the GOTEK - I'd be interested to see if the Amstrad CPC could be supported.
CPC 6128 is supported quick and easy to flash. Those having blue screen issues are probably using pirate clone USB TTL flashers. Mine worked fine on W7Ultimate 64bit. Took seconds
