Sure!
I tried everything, reseating the socketed chips, change jumper config, tested volts on the power supply, and nothing. It had little battery damage, that I cleaned, but that was not enough. I ended up sending it to the user hese and he changed many components near the battery, then it worked again.
Read this entire post, try everything that is suggested...
