I cannot get Rick Dangerous to work properly on my A4000
  • Thread starter Thread starter dougal
  • Replies Replies 30
  • Views Views 5278
Just tried RD 1 and 2 on my 4000 and no problems here whatsoever. Same as fitzsteve, no additional tweaks in tooltypes for it to work.
4000 with 16Mb on the main board, 040@25Mhz and whdload 18.
I see your 040 is at 33Mhz. Is that an over clocked 3640? If so, does that affect bus speeds/timing?
According to WhichAmiga the CPU is an MC68040 at 33mhz and yes the A3640 is modded witha 66mhz xtal and has some jumper wire mods.
I'm guessing besides the mod on the board and xtal the cpu was also replaced.
Aside from Rick dangerous all other stuff works fine and the Amiga is stable.
Maybe just play rick dangerous via the gotek?
Didn't the op say that it glitched from floppy too?
Hmm I interpreted this as a probable whdload/040 issue?
Op said he also tried playing from disk and disabling cpu caches do its not a whdload issue as such however whdload normally can fix these issues through patching.
I get a small graphic glitch once the rock has fallen down the first drop.
A slight corruption in the channel.
Running a 4000D with WarpEngine
